Everything seems to be working fine with my Mega board now that I have the Reset function working correctly (https://forums.homeseer.com/forum/hs...et-not-working), however still have a bit of an issue with auto connect when I temporarily cycle power (I think).
If I drop power or network connection for sometime (say more than 30 secs), the board reconnects just fine after sometime. If I remove power from the board temporarily (say less than 5 secs), the relays de-energise and LCD goes out. HS4 still reports as "connected". When I re-power, the board doesn't appear to properly re-initialize. i.e. LCD does not come back on properly and relays don't go back to proper state. It still appears to be communicating but unless I re-connect or reset, it remains in this state. Is this correct behaviour or should the board properly re-initialize immediately on power cycle?
