I would like to add wind speed to HS4 and have looked at various sensors available, the most common being a 2 wire reed relay pulse device that produces a switching stream for the rotation speed of the sensor.
Can I use the arduino plugin to set this up on a pin to get the raw count so I can send it to Nodered?
If so what type of pin in the plugin to use, the tutorial for the wind speed sensor says to use an interupt pin to count the pulses.
