moving for HS3 to HS4... and sorry if this is covered somewhere but i can't find it.
Just install over? I saw you could use your current hspi_BLDenon.ini from the HS3 plugin
Just make sure you rename it to BLDenon.ini
Does that mean it installs in new folder? (assume so)
Then will i have to fix/upgrade my HSDesigner applciations to work with it?
Thanks so much.
Thanks so much.
