Did the dev even test the chromecast plugin? Im getting an incorrect file path error when I add and run mp3 files with the play audio function. Notice the backslash instead of a forwardslash. And there's no option in the ui to remove uploaded mp3 files. This is on hs4 raspberry pi 3b+. The file will not play.
Time
From
Type
Message
11/18/2020 3:15:00 AM
Chromecast
Error
System.IO.DirectoryNotFoundException: Could not find a part of the path "/usr/local/HomeSeer\Media/welcome.to.quake.3.arena.sound.max.mp3". at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.Boolean anonymous, System.IO.FileOptions options) [0x00164] in :0 at System.IO.FileStream..ctor (System.String path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share, System.Int32 bufferSize, System.IO.FileOptions options) [0x00000] in :0 at (wrapper remoting-invoke-with-check) System.IO.FileStream..ctor(string,System.IO.FileMode,System. IO.FileAccess,System.IO.FileShare,int,System.IO.FileOptions) at System.IO.FileSystem.CopyFile (System.String sourceFullPath, System.String destFullPath, System.Boolean overwrite) [0x00025] in :0 at System.IO.File.Copy (System.String sourceFileName, System.String destFileName, System.Boolean overwrite) [0x00062] in :0 at System.IO.File.Copy (System.String sourceFileName, System.String destFileName) [0x00000] in :0 at HSPI_Chromecast.ChromecastTarget.PlayAudioFileEventHandler (System.Object sender, HSPI_Chromecast.SpeakerClient+PlayAudioFileArgs args) [0x00087] in :0
HomeSeer
Event
Event Trigger "voice commands test event"
HomeSeer
Event
Event voice commands test event triggered by the event page 'Run' button.
Time
From
Type
Message
Chromecast
Error
HomeSeer
Event
HomeSeer
Event
