I have recently changed to using a docker setup and Chromecast has broken. However I can see where it appears to be broken.
Homeseer HS4 Standard Edition 4.1.11.0 (Linux)
Mono JIT compiler version 6.12.0.107 (tarball Thu Dec 10 05:28:17 UTC 2020)
Lan IP 172.17.0.2 (d5f905df362e)
Plugins:
Chromecast 4.0.17.0,
Harmony Hub 3.7.2.0,
mcsMQTT 5.3.0.4,
Z-Wave 3.0.2.0
When I test TTS I get this message
Playing http://172.17.0.2:80/Chromecast/audio/chromecast20210127221412573.mp3 on Bedroom speaker
I am unable to play this file because 172.17.0.2 is the internal IP of the container and not externally accessible.
If I change the IP 172.17.0.2 to the IP of my docker host I can play the audio file.
Ideally it would be good if somewhere we could specify the IP / hostname that is used and this would fix the problem for anyone behind some kind of proxy device or using docker. This does not appear to be an issue for the HomeSeer UI as it seems to be using relative URLs which allows HS to run on one IP:PORT and have me map it to another with Docker.
Brad
Plugins:
mcsMQTT 5.3.0.4,
Z-Wave 3.0.2.0
Brad
