Noticed this in the startup log, not really sure what to do about this?
3/31/2021 4:47:04 PM Chromecast~!~Error~!~System.BadImageFormatException: Could not load file or assembly 'SharpCaster, Version=1.0.0.5, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The module was expected to contain an assembly manifest.File name: 'SharpCaster, Version=1.0.0.5, Culture=neutral, PublicKeyToken=null' at HSPI_Chromecast.ChromecastTarget..ctor(String id, String name, String ipAddress, Int32 port, Boolean enabled, Boolean tts) at HSPI_Chromecast.ChromecastTarget.CreateFromINI(String id)WRN: Assembly binding logging is turned OFF.To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.Note: There is some performance penalty associated with assembly bind failure logging.To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].Startup Complete, 1 errors detected, check the log for more informatio
