Can't get audio to play via event
    I'm trying to set up an event to play brown noise on some Nest hubs. The "test" in the plugin's Chromecasts Management works, and plays a voice through the speaker.
    But when I run the event, nothing happens. This is the test event I configured:
Name:	Screen Shot 2021-10-23 at 11.23.43 AM.png
    And this is the log:
    10/23/2021 11:21:57 AM
    Chromecast
    Debug
    Office Nest Hub : media status changed, player state = Idle
    Chromecast
    Debug
    Office Nest Hub : chromecast status changed
    Chromecast
    Debug
    Office Nest Hub : application started Default Media Receiver
    Chromecast
    Debug
    Chromecast
    Debug
    Chromecast
    Debug
    10/23/2021 11:21:56 AM
    Chromecast
    Debug
    Playing c:\audio\brownnoise.mp3 on Office Nest Hub
    HomeSeer
    Event
    Event Trigger "New Event"
    I'm fairly sure I'm just doing something wrong, but I can't quite figure out what.
    This is an old post. Sorry you didn't get any help.
    When I want to play sounds through my speakers I use the native HomeSeer "Play an Audio File" action with my desired speaker or speaker group selected. I recommend using speaker groups if you wish to target multiple speakers at the same time.
    Note my file is in c:\Program Files (x86)\HomeSeer HS3\Media\. File location might matter. I don't remember.
    Click image for larger version  Name:	Screenshot.png Views:	0 Size:	89.8 KB ID:	1532339
    In your example, the Media URL is not a valid URL. If it's going to work at all, you need to provide a URL that your Chromecast device would be able to access. For example: http://192.168.1.100:8080/folder/filename.mp3. My guess is that is what "Play an Audio File" does under the hood when a Chromecast device is selected. I would just use "Plan an Audio File" and only mess with this plugin's "Cast Media" action if you want to cast something other than an audio file, for example a camera's video stream.
    HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
    Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Harmony Hub, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
