Hi all:
Recently, say the past month or so, my Nest Hub Max which I use for TTS has been disconnecting from HomeSeer. It stays connected for no more than an hour. The Chromecast plug-in Manage Chromecasts page indicates it is offline even though it has a functional network connection. Interestingly enough, the other Nest Hub I have on my network, which I do not use for TTS, also disconnects intermittently. I can get them back online by disabling and re-enabling the Chromecast plug-in. All other Chromecast devices on my network - a mix of Nest Mini speakers, Chromecast with GTV, ONN Media devices, and Smart TVs with Chromecast built in - remain connected to the Chromecast plug-in. It appears the issue is isolated to Nest Hub Max and Nest Hub.
Here are the log entries from the last time the Nest Hub Max disconnected. I am on HS4, release 4.2.15.0 with Chromecast Plug-In v4.0.18.0
9/24/2022 11:22:04 AM Chromecast Info Disconnected from chromecast Nest Hub Max
9/24/2022 11:22:04 AM Chromecast Info Speaker client Nest Hub Max has disconnected
9/24/2022 11:22:04 AM Chromecast Info Disconnecting from Nest Hub Max https://[IP ADDRESS REDACTED]:8009/
9/24/2022 11:22:04 AM HomeSeer ASR Speaker Client speech recognition stopped
9/24/2022 11:22:04 AM HomeSeer Speaker Speaker host disconnected, Name: CHROMECAST IP address: 127.0.0.1
9/24/2022 11:17:04 AM Chromecast Info Unexpected service _googlecast._tcp.local.
Any insight would be appreciated!
