I've already purchased another plugin, but it seems the only thing lacking from this one, for me, is the sleep timer functionality. I like the UI on this one better than the one I purchased, but since I can't control, or see if the sleep timer is already set on the hub, I can't use this one. Any idea if this feature will be added?
Sooo close!
I'm comparing this to the meiharmony plugin -- they have a sleep timer set of controls on there.. that I guess get it's information from the hub. If I set the sleep timer on the hub via the remote, it is displayed in the plugin and I can change/set it from there as well. Basically what i'm after is to automatically turn off the TV at midnight, unless the sleep timer is already set from the remote.
Originally posted by Demusman View Post"sleep timer" would be a feature of the TV, not the Harmony hub.
If your TV has a sleep function, it would be listed under the TV controls.
Um, nope. It's at the activity level. On the remote, you hit the little gear icon at the top and it's a sleep timer for the activity. https://support.myharmony.com/en-us/...ty-sleep-timer
- Likes 1
Originally posted by Demusman View PostThen just set an event. Why would that be so hard?
How do you create your own HS sleep timer that can be set using the Harmony remote?
He has a valid need. I'm not doing exactly what he is, but I do make good use of the built in sleep timer, as well as an HS timer. If I set the Harmony timer, then I over-ride my HS timer. It's a matter of user interface and convenience.
- Likes 1
