Ok, need some suggestions. Old HS3 Plugin used to work. I deleted it and added the new HS4. I set static IPs on both the SEL Linux box (10.0.0.50) and the Harmony Hub. (10.0.0.18).
HS4 is on 4.1.2.0 and Hub Plug-in is on 4.0.11.0
Harmony Hub is 4.15.264
I have turned on XMPP.
i have rebooted both HS4 and Hub. I check hub right before sending this and turns on TV, channels, etc as expected from Harmony Hub app. App confirms the IP address and so does the router.
When I go to step 3 and put in the IP address of Hub, I get “error while connecting to 10.0.0.18 Hub: Exception has been thrown by the target of invocation”
I have tried all I can think about. Suggestions please?
thanks,
Joe
thanks,
Joe
