Reolink Video Doorbell Integration with HomeSeer
    #46
    [QUOTE=Mikeep;n1612717]Plugin works great with my old RLC 410’s
    /QUOTE]
    I bought a few of these cameras on Fleebay for $33.99 each (free shipping) certified refurbished with a two year warranty. They look just like new and work great with HS4! You can get the 5MP version for $48.74.
      #47
      You are running HS4 version 4.2.18.9 or later correct? Are there any errors in the log? Normally an error is logged if it cannot reach the camera.
      Originally posted by ben pownall View Post
      So , tried all the property config. Updated to latest beta hs4, used onvif manager to view reolink doorbell and still no feed in hs4 cameras. Camera is detected automatically now my although it does say on detected cam "manually added".
      Any suggestions?
        #48
        Good info, I would like a couple more, thanks for posting!
        [QUOTE=Bigstevep;n1614274]
        /QUOTE]
          #49
          The Doorbell and Cameras can easily be set up to record and store all video to a NASS for less than $100. I used a RPI 3 I had laying around with a 2TB USB drive. Basically just install Open Media Vault (free) on the RPI, set up FTP on OMV, add your USB drive to the storage and then create a share folder for your bell, cameras and have them FTP to that folder. If you allow your NASS, bells, cameras to create folders videos and jpeg files will be saved to the file structure of:
          Your share folder name
          2023 (year)
          5 (month)
          11 (day) and the files will be saved there. As the day changes the day number will automatically change as well.
          The files will be saved with the bell, camera name and a time stamp.
          Tips: 1. Format your USB drive NTFS this way if your RPI fails for some reason you can just plug in the USB drive into a computer and see all the videos, etc.
          2. Set up the SMB/CIFS service on OMV and you can see the files on your PC and view them there via your network.
          There are plenty of videos and instructions on setting up OMV on the RPI. If you don't have the RPI or USB drive you can buy the setup I have for less than $100 on Fleebay.​
            #50
            I have the latest beta Click image for larger version
Name:	Screenshot 2023-05-12 154445.jpg
            but no errors from HS4 in my Log.
            Interestingly enough, the Reolink doorbell has now disappeared from my Auto discovered cams. I have tried turning off the auto-discovery, saving, turning on again and saving again. Still no luck. It picks up the Foscams I have well though.
Name:	Screenshot 2023-05-12 154827.jpg
              #51
              Try restarting HS and see if they appear.
                #52
                Result.... It found the cameras again.
                Click image for larger version  Name:	Screenshot 2023-05-12 164938.jpg Views:	0 Size:	29.3 KB ID:	1614422
                and I re-entered the password and user.
                I now get a feed.
Name:	Screenshot 2023-05-12 165618.jpg
                Thankyou for your patience with me.
                One point though.... picture one above still says (manual) for some reason. But not bothered as it is now working.
                Again
                  #53
                  I think the "manual" thing is from a previous version of HS. Give it some time and see if changes to "Reolink". If not, you can manually edit the HSPI_HSTouch.ini file and remove that camera, then add it back after HS is restarted.
                  I now get a feed.
                  Again
                    #54
                    Originally posted by JRose View Post
                    Also works with Reolink RLC-811A​ and Reolink E1Zoom
                    And with Reolink E1 Outdoor
                      #55
                      New Reolink doorbell camera firmware v3002023_23041302 has settings to sort out the wafty GOP/I-frame in Blue Iris. Now all =1. Testing...
                        #56
                        I must be missing something simple...
                        I purchased one of the Reolink WIFI doorbells...
                        I am powering it the original circuit
                        I can HTTP to it on port 80 from my laptop
                        The app on my iphone see it
                        I am running HS4 Current Version: 4.2.18.15
                        I get notifications on my iPhone from it
                        I have updated the doorbell to the latest firmware...think that was May 7
                        If I just use HS4 automatic discovery it finds it...but can't pull video from it
                        When I load the ONVIF plugin it says it adds it...but never add any features and I see nothing in the log
                        It doesn't matter if I delete all my HS4 cameras by turning off auto discovery and then just try with the ONVIF plugin...or visa versa.
                        I've tired ports 8000, 9000, 80, and 8080
                        It just doesn't work.
                        Any ideas?
                        THANKS!!!
                          #57
                          Did you try manually adding the camera by it's IP address on Port 8000?
                            #58
                            Yes...that may be the problem actually...auto discovery now says (Manual) beside this discovered camera. I think I need to edit those files mention in the HSTOUCH folder to delete things...as no delete/trash can show on those. It will be a couple days before I can get around to that. Thanks for the help.
                              #59
                              I noted that the Reolink doorbell camera doesn't do WDR. If somebody walks towards it on a bright day, good picture. Just as they get close to it to press the doorbell, they walk into the covered alcove by my front door and the camera can no longer see the face as the image becomes too dark. Bit of a problem that as it prevents face recognition working with Blue Iris (and CPAI)
                              Almost...
                                #60
                                does this trigger/work on a doorbell press?
                                HS3 Pro on Windows 8 64bit
                                53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
                                Check out my electronics blog here:
                                https://www.facebook.com/RaptorsIrrationalInventions
