Cannot authenticate latest beta 1.0.0.28 BETA
    Hi. I installed the plugin and tried to include my credentials, but the only popup I get is invalid credentials. I know they are correct. I do have 2FA with an authenticator app as the 2nd authentication, but it doesn't prompt me to enter anything, just the invalid message.
    Any ideas?
    Thanks.
    Any ideas?
    Thanks.
    What OS are you running this on? Another user had an issue because he was on Win7 and didn’t have .net up to latest (4.7x). Can you set debug level to errors and events , do your authentication, post the log. First check there are no proprietary things in log, I believe I prevent them from showing up in the log but double check before posting it PM me
      Hi dcorsus. Thanks for the response. I'm running on a Windows 10 machine. I'll try to send you the log shortly. Thank you.
        dcorsus I just pm'd you my logs for the plugin.
          After you enter the password, you need to click on that fully authenticate button. The log doesn't seem to show any activity or you didn't increase the debug level to "errors and events".
          What browser are you using? Make sure you don't miss that pop up window where you should enter your code.
            Sorry. You are correct I forgot to change the log level. I re-sent the log to you via DM. Thanks!
              I'm using Chrome and not getting any pop up window to enter my code.
                Send you a response. Ring says invalid credentials so enter them again to make sure. I know using an Authenticator app works because someone on this forum wrote it
                  Okay. Confirmed. I re-entered the credentials and this time I got the authenticator popup and it worked. Sorry, I thought I had tried re-entering the credentials before.
                    Great, suggest you edit the visitor message to me and remove the attached log, I can't do it
                      Okay. Will do. Thanks!
