I just added a First Alert ZCOMBO smoke/CO detector to my Ring system and noticed it showed up in Homeseer (without needing to do a device refresh, nice!). It shows up in the Ring app (and Homeseer via this PI) as two separate device: smoke alarm and CO alarm. But in HS there aren't any features. I know I saw mention of the listeners being used with this PI, but is there anything extra that should show up for this device?
That first device ("First Alert CO Alarm") I need to delete from HS because I started adding it to Ring and the messed up and had to remove/re-pair it. It's the second two that are "real."
I also noticed a new "Active Reminders List" feature under my base station. Maybe it was there before (but it's device number is sequentially right before I started adding the ZCOMBO). What is that for?
Thanks!
Thanks!
