Authentication ptoblems
  • Mario23
    Yes sorry for the trouble...user error
  • dcorsus
    Originally posted by Mario23 View Post
    Yup...sorry. I missed a key somehow. Tks
    So working now?
  • Mario23
  • dcorsus
    My bad I found it and your right.
    1/26/2024 10:16:52 AM
    Ring
    Warning
    Unsuccesfull getAccessToken while sending URL = https://oauth.ring.com/oauth/token, body = {"client_id":"ring_official_android","grant_type":"passwo rd" ,"password":"XXXXXXX","username":"XXXXXXX","refresh_token":" ","scope":"client","api_version": 11,"device_model":"homeseer-ring"} and error = The request was aborted: Could not create SSL/TLS secure channel.
    Not sure what I did wrong but I'll check the regedit.​
    Ah that is indeed the typical error , which 2 other users (if you look through this thread) seem to have fixed. You may have to reboot your PC to have it take effect.
  • Mario23
    Ring
    Warning
  • dcorsus
    This I hope?
    2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 véW a r n i n g W a r n i n g i n Q u e u e A P I C m d . N o a c c e s s t o k e n , p l e a s e a u t h e n t i c a t e ! ! R i n g F¦5
    Y)‚
    2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 véW a r n i n g W a r n i n g i n Q u e u e A P I C m d . N o a c c e s s t o k e n , p l e a s e a u t h e n t i c a t e ! ! R i n g F¦4
    Y)‚
    2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 véW a r n i n g W a r n i n g i n Q u e u e A P I C m d . N o a c c e s s t o k e n , p l e a s e a u t h e n t i c a t e ! ! R i n g q¦3Ye
    2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 uÉùI n f o R e t r i e v e S e s s i o n c a l l e d R i n g ¦2
    2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 uÉùI n f o R e t r i e v e R i n g D e v i c e I n f o r m a t i o n c a l l e d R i n g
    Ë Ë û+[‹»ëK|­Þ>nžÏp Ð /Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 uÉù3/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 vé4/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 vé5//Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 uÉù2/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 uÉù3/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 vé4/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 vé5/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 7 vé6/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 v7]7/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 v7]8/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 v7]90Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 —Ô
    :0Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 —Ô
    ;0Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 —Ô
    </Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 5 2 d½ò=/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 5 2 dúâ>/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 5 2 dúâ?/Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 5 2 v$¢@0Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 5 7 †x[A0Y2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 5 7 †µKB
    Ù 6lâ Ù ‚¦:
    I n f o P o s t B a c k P r o c c a l l e d w i t h p a g e = s e t t i n g s . h t m l a n d d a t a = b u t t o n C l i c k e d = t a b C l i c k & t a b I t e m = G e n e r a l R i n g ¦9
    2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 v7]I n f o R e f r e s h W S A l a r m I n f o r m a t i o n c a l l e d R i n g F¦8
    Y)‚
    2 0 2 4 - 0 1 - 2 6 1 0 : 1 6 : 4 9 v7]W a r n i n g W a r n i n g i n Q u e u e A P I C m d . N o a c c e s s t o k e n , p l e a s e a u t h e n t i c a t e ! ! R i n g F¦7
    Y)‚
    hmm what format is this? A word document format? Just copy/paste directly from your HS Log into here. I have the impression your problem has nothing to do with .net or tls1.2.
    You did enter your credentials and clicked "FULLY AUTHENTICATE RING CLIENT", right? NOT "REAUTHENTICATE ..."?
  • Mario23
    This I hope?
    Y)‚
    Y)‚
    Ù 6lâ Ù ‚¦:
    Y)‚
    Y)‚
  • dcorsus
    I did those steps.
    Is this what you were looking for?
    Ring Device List
    {"master":{}}
    Ring Device : master
    deviceauthenticationhsref = 241
    devicehistorycounthsref = 242
    devicehsref = 239
    deviceid = master
    devicestatushsref = 240
    featurereflist = {"239":"devicehsref","240":"devicestatushsref","241":"dev ice authenticationhsref","242":"devicehistorycounthsref"}​
    Nope, you go to the setting page of the plugin, debug tab, set debug log level to errors and events. Then you go to the general page where you should have entered your Ring credentials and the click on "full authenticate". I assume you have a 2 form factor authentication on your ring account, so you will get a txt message or an email with a code. A pop up should have showed up where you enter this code. If you don't get the pop-up you pull up the HS log and post me the log entries generated by the plugin. I don't think there is personal info in it, but check it anyway before posting here. You can also PM me.
    *IF* this is a TLS1.2 issue, we should see the error in the log ....
  • Mario23
    I did those steps.
    Ring Device List
    {"master":{}}
    devicehsref = 239
    deviceid = master
  • dcorsus
    I followed the steps and still haven't gotten anything to pop on authentication. I'll take another look to make sure I did the regedit correctly.
    I'm on an older pc with windows 7 and I installed .net 472 but I was curious...would the newer versions also be ok or just stay with that one?
    I can't currently think of anything I've missed.
    Tks
    Mario23 Did you follow these steps?
    https://forums.homeseer.com/forum/hs...52#post1618652
    Still would like to see that log to confirm this is the same issue
  • alexbk66
    I wasn't able to fix TLS problem on Windows 7 (and a few of my users tried too).
  • dcorsus
    Tks
    Can you raise the alarm level to "errors and events", restart the plugin, click on fully authenticate. What do you see in the log?
  • Mario23
    Tks
  • alexbk66
    Originally posted by dcorsus View Post
    Thanks alexbk66. I guess in this case the ring server isn't needing a special cipher
    Again, depends on client Windows version (and build number) too.
    FYI, ring serever is also using AWS, but has more cipher suites supported (at the moment):
  • dcorsus
    Thanks alexbk66. I guess in this case the ring server isn't needing a special cipher but good to know there might be more needed.
