Errors in log
This topic is closed.
    Errors in log
    My system was acting up so I just looked in the log and I am getting errors.
    Jim
    Please provide output from Tools => Help
      Date/time=6/15/2022 10:01:46 PM Pacific Daylight Time
      Version=HS4 Standard Edition 4.2.13.0 (Windows)
      License=Registered
      Confguration File=C:\Program Files (x86)\HomeSeer HS4\Data\HomeSeerData.json
      In Virtual Machine=No MFG: hewlett-packard
      Antivirus=Windows Defender Avast Antivirus
      OS=Microsoft Windows 10 Pro - Work Station
      OS Version=10.0.19044
      Uptime=0 Days 10 Hours 5 Minutes 31 Seconds
      Lan IP=192.168.1.180 (Homeseer)
      Device Count=422
      Event Count=63
      Processor:=Intel64 Family 6 Model 60 Stepping 3 at 2.61 GHz
      Modules/Threads=102 Modules, 123 Threads
      Available Threads=1023
      System Load=187 Processes, 6% Load
      Free/Total Memory=1.54 GBytes / 3.92 GBytes (39% free)
      Free/Total Virtual Memory=2.88 GBytes / 5.79 GBytes (50% free)
      HomeSeer Memory Used=123 Mbytes
      Plugin Memory Used=12 EXE Plug-Ins using 401 Mbytes
      Plugins Installed=AK EnphaseEnvoy 4.0.0.23,BLBackup 2.0.63.0,BLLock 3.0.39.0,BLShutdown 1.0.6.0,Chromecast 4.0.18.0,Device History 3.3.1.0,EasyTrigger 3.0.0.74,EnvisaLink 3.0.0.42,Honeywell WiFi Thermostat 1.4.2.2,NetCAM 3.0.0.14,SDJ-Health 3.1.0.9,Z-Wave 3.0.10.0,Z-Wave UI 1.0.0.0
        Please install latest BETA (4.0.0.29). You need to enable "Show Beta Plugins" in Plugins => Add
          I've been busy and just updated to 4.0.0.29. Still having problems.
            [EDIT]
            Please try ver 4.0.0.30 (BETA)
            If still doesn't work - please start the plugin manually from terminal (console) window in HS root folder and see if any errors there.
              I just installed the beta version and it had an error starting up after install.
              I restarted HS4 then got this.
              I will try what you said in your previous post.
                When I started the plugin manually my Avast Antivirus software didn't like the plugin. I had to add an exception for it to start anyway and not block it. This was probably the problem the whole time. I forgot that this sometimes happens when you install a plugin. Homeseer is on a laptop in the living room. I hardly ever get on it. I mess with HS4 from my laptop in the bedroom so I was missing the prompts from my Antivirus.
                Should I leave the Beta installed or should I go back to the regular version?
                Jim
                  Good news you found the issue. I missed in the info you provided "Avast Antivirus". BTW, I think Windows 10 built in antivirus is sufficient (Windows Defender) - but it's my opinion.
                  Latest BETA is fine to keep - I'm working on new authentication for FW 7.x, which you may need at some stage.
                    Sounds good thanks
