NP. Feel free to remind me.
Feature Requests
This is a sticky topic.
Originally posted by Freddan101 View PostDon't know if this has been up for discussion before but I have a need to have the Calendar Event string split up so that the event name, weekday, date, month and time are split up in separate devices. In this way it would be much easier to get a custom layout in HS Touch when presenting events.
I realize that it would mean that many more devices have to be created, but i see it working in for example the YR Weather plugin which is very customisable.
Hello,
I wanted to check in on this feature request and the other one about having the date/time before the event name.
Thanks!
Originally posted by ckellyusa View PostHello, I wanted to check in on this feature request and the other one about having the date/time before the event name. Thanks!
I don't like having separate devices for each part (unless absolutely necessary), I think it's better to have configurable format for single device.
I'm open for suggestions.
Oh, just as the others have described.
Ideally I'd like the date and time to be separate so when arranging in HSTouch (or other dashboards) you have complete control of the layout and looks.
But if we can't do that, then having the date/time before the Event Name would allow for more organizing of the events on the dashboard.
So, ideally you suggest for each event have 3 devices (1) Description, (2) Date, (3) Time?
I can implement anything, just can't imagine how it's gonna look
[EDIT]
Another option would be to have separate root devices for each calendar - for (1) Description devices, (2) Date devices, (3) Time devices
Originally posted by ckellyusa View PostCan you explain how the difference between the event and root devices would be if you separated them?
Originally posted by ckellyusa View PostSo I played around with Node-Red some more and I think this will work for me:
I created a sequence to split the calendar status into two virtual devices:
And then here are the virtual devices in HS:
I think I'll be able to make this work to populate my Dashboards the way I want!
