alexbk66, anyway you can add an option to ignore all-day events? This integration is working perfectly for me now, but whenever I have an all-day event it breaks my triggers because none of the other events that day will fire.
Ignore all-day events
I don't see anything specifically wrong in the log, but I have triggers that turn my light red when an event starts and turn it blue when an event ends. When I have a full-day event on the calendar, it triggers (turns red) on that first event when it starts, and then doesn't turn blue until the event ends (end of day), ignoring all the other events that happened throughout the day.
DebrodeD took me a while to look at this. Not sure if it's an issue with the plugin - can you please provide more details about your triggers, especially how "doesn't turn blue until the event ends"? How do you expect to trigger on the other events if you set it up the way that the light stays red until the event ends?
alexbk66How do you expect to trigger on the other events if you set it up the way that the light stays red until the event ends?
Originally posted by DebrodeD View Postalexbk66
This is exactly the issue I'm having. I'm not saying anything is broken with your plugin, I just need the ability to "ignore all day events". The problem is that my work calendar that I use has all my meetings on it, but also occasionally has events that span multiple days above it all. I always have to delete those multiple-day events in order to keep my regular meeting events working as intended. I'd rather not have to curate my calendar in order to get the integration to work.
Happy New Year
Alright, the beta with the "ignore all-day events" didn't work for me, but I think I know why. I created a few test events today as well as an "all-day" event and none of the regular test events triggered, despite me having the new "ignore" box checked. I'm guessing that's because the way your calendar plugin works is that it looks at the top event, but when the event is all-day, it never leaves that top spot, preventing any subsequent events from triggering. I believe that's because I have this checked:
But unfortunately, I need that to be checked so I can trigger off of events ending as well. Would it be possible to implement an "ignore all-day events" checkbox into the calendar settings itself so they don't even show up in that top spot?
