Traccar Feature Requests
This is a sticky topic.
    Please add your desires here
    My request
    - Device showing map with position
    - Device for Battery level
      Originally posted by antoon View Post
      My request
      I'm working on this. For battery level I need JSON responses from you.
        If you can tell me how then I will do
        Verstuurd vanaf mijn SM-N975F met Tapatalk
          Ver 4.0.0.13 - Added Google maps
          Ver 4.0.0.14 - Added Geoapify maps
          Ver 4.0.0.15 - Added reverse address geocoding
          Ver 4.0.0.16 - Added geofences
            GeoFences... Part of Plug-in or Program ??
            want to add fence around home, and have it sense when tripped by cars/phones arriving
            probably will add for work to signify leaving work to head home
            THANKS again for the Plug in, the script was way way over my head
            Geary
            Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
              Hi Geary, GeoFences are implemented on the server and supported by the plugin.
              When you setup Geofence on the server - the plugin will create HS device automatically.
              If you have any problems, please start new thread.
                Anybody have interest in showing attributes, i.e. "io1":"204","io2":"04","io3":"00212","io4":"19642"?
                  These values has something todo with the mcc-mnc codes from the provider you are using in the tracker
                  For example my says 204 - 04 thats Vodafone Libertel Netherlands
                  See this site
                  https://www.mcc-mnc.com/
                  I know these are attributes provided by the tracker and are different for different trackers. I was just wondering if anybody was interested in displaying any of these in the plugin somehow?
                    Hi Alex,
                    Is it possible to hold the geofence information (date / time) after a restart from HS or plugin?
                      Hi Alex,
                      Hi Antoon, Anything is possible. But what exactly you want to keep? Because geofence information is only in/out?
                      [EDIT]
                      Do you mean the time for in/out events? But then I need to add HD devices for time? How do you see it?
                        I mean the date / time after the geofence out, see below
                        Want to know when I was for the last time on that area
                          That's the "Last Change" time shown by HS, do you mean when plugin restarts - it shows the restart time and you want the time not to change?
                            Yes correct.
                              Ver 4.0.0.44 - Don't reset devices to Unknown on start-up
                              I usually set all devices to 'unknown' on start-up just in case, but this changes the "Last Change" time.
