Maps API configuration
This is a sticky topic.
    #16
    You can try other provider, i.e. Geoapify, or LocationIQ (I think not included in your version yet) - they are way easier to setup
      #17
      got it, super support from google, had to cut and paste my key and it fixed a 0Oo problem
      we now be working !!
      It looks like you resolve separately from Traccar, as it still uses their default map.
      when I get crazy, I will modify their file to use google again as I now have the corrected key
      Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
        #18
        working... tried to geo fence... shows in Traccar, no new devices
        rebooted, same....
          #19
          rebooted, same....
          Hmm, need to check...
            #20
            Geary, try ver. 4.0.0.24 - not sure if that's the cause, but there's an API argument to force loading geofences from server database. I set it to force on plugin start-up and when you click "POLL" button.
              #21
              spent the day cleaning up z-wave and chasing traccar problems ..
              still working on getting my Trike back into Traccar, but close, real close..
              geofences added, trackers assigned, still no devices, will probably work on it tomorrow
              sorry been gone the last few, work... that four letter word
              Geary
                #22
                Google going crazy, switched to Geoaify, what API do I need ??
                  #23
                  First check https://forums.homeseer.com/forum/hs...ange-detection
                  Free Geoapify should be sufficient, Bing and LocationIQ also don't ask for credit card - so should be safe.
                    #24
                    Note that StreetView works for Google. Bing depending on location.
                      #25
                      Ver 4.0.0.40 I added the Maps API calls counters - Daily (auto reset) and Total (manual reset). Helps to monitor and trigger alarm if calling API too often:
                      Click image for larger version  Name:	bridge with cntrs.jpg Views:	0 Size:	46.9 KB ID:	1471161
