lot of new errors ...
    did something... my system has gone south, traccar seems to be ok, but plug-in is throwing this... Ver .29
    Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
    Hi Geary, it seems like some HS issue - HSCF is the HS library. But it's hard to tell because the error info you posted is incomplete.
    Can you please copy the whole error you get - as text, not screenshot.
    -Alex
      Ver 4.0.0.31 (in BETA) - Exception handlers in CAPIGetStatus and CreateDevice
      Please see if it helps. I can't really test as it looks like issue only on Linux, CAPIGetStatus is old HS3 function, not ported to HS4 for some reason.
        31 installed, seems that Google has blocked you...
          Click image for larger version  Name:	blocked.jpg Views:	0 Size:	44.8 KB ID:	1468707
          Geary, where do you see this message? What happens if you click "Learn more"?
            they emailed it... it is going crazy blew by the $200 allocation..
            need to find what is causing it.. Off tomorrow
              I went to account set up and set this switch .../
                But what "app"? This can't be my plugin because it's using their API and their access token. "Less secure" app is using username/password.
