Connection problems with server
    I am running the server local on my server, my phone is connecting to the server and data is recieved by the server
    So far, so good
    But i can't get the plugin to work to connect to the (my) server
    ip= server ip, port= 5055
    and i don't know what to use for login and pasword. empty doesn't work, original login (email and pasword) doesn't work
    Any idea what i do wrong?
    Click image for larger version  Name:	err.JPG Views:	0 Size:	26.6 KB ID:	1482874
    error in device list:
    Execute(sync) (Devices) [https://192.168.1.140:5055/api/devices]: De onderliggende verbinding is gesloten: Bij verzending is een onverwachte fout opgetreden. [De handshake is mislukt als gevolg van een onverwachte pakketgrootte.] [Status = SendFailure]
    no error in the log:
    7-7-2021 18:34:14
    AK Traccar
    Trace
    [3604] 192.168.1.140: Execute(sync) (Devices) [https://192.168.1.140:5055/api/devices]
    7-7-2021 18:34:14
    AK Traccar
    Trace
    [3604] 192.168.1.140: Execute(sync) (User) [https://192.168.1.140:5055/api/session?
      I guess it has something to do with the https? https://192.168.1.140:5055/api/devices]
        You must use the port from the traccar server.
        Also the login and pass from it.
        Verstuurd vanaf mijn SM-N975F met Tapatalk
          Yes, that is port 5055
          and that is also not working.
          Are you running it on a server at home?
            Yes i am running traccar server on my homeseer system.
            I have port 5055 on my Phone but traccar is running on another port.
            I tought it was 8085.
              antoon are you using http or https? I suspect https needs SSL ceritificate?
                Also, port 5055 is for the tracker device, but in the plugin you should use the traccar webserver port, which I think is 8081, but you need to find out about the Traccar webserver configuration, probably on Traccar forum.
                antoon, gearyt can you please post screenshots of your plugin config
                  I use http, see settings
                    Try enter URL http://192.168.1.140
                    And port 8082
                      And port 8082
                      It's working
                      changing the url to http:192.168.1.140 changed the url in the plugin to https://http192.168.1.140
                      i had to remove the plugin and install it again
                        It's working
                        Removing plugin doesn't do anything. Deleting the root device deletes the configuration, but uninstalling plugin just deletes the executable file.
                          I removed everything, but it's not clear why the plugin added https in front of http.. but it's working!
                          now looking how to get my adres (position) in homeseer
                            I'll check
                              Google Maps is probably best option, but I think they provide $200 credit per month, so you need to adjust configuration carefully so it doesn't request location too often
