Release 4.0.36.0, currently available as 4.0.35.x beta
- New: License Plate detection
- New: EventTrigger for License Plate matching
- Imp: Minor fixes and improvements
- New: USP-PDU-Pro support
- New: Support for v2 Custom API calls
- Fix: Custom API call parse error on unnamed JSON array
- New: WAN1 & WAN2 State, IP and Rx/Tx
- New: Added B/s for all Rx/Tx fields
- Imp: Mark all throttled features with *
- Fix: JSON view for UDM series
- Fix: UDM-SE image in setup
- New: EventTrigger on (dis)connect of UniFi Applications
- New: Support HS4 search functionality for events actions
- Fix: Event triggers and actions due to a change in HS4 4.2.17.0
- Fix: Blank settings page for UDM SE
- Fix: “Enable all properties for all UniFi devices” creating redundant features
- Fix: Duplicate Chime setup options
- Fix: Crash when client tracking Feature already exists as a Device
- New: Replace UniFi client
- New: Optional connection information logging
- Imp: “State” values for UniFi Network devices
- Imp: Client tracking when using non-UniFi devices
- Imp: Threads/UniFi Applications handling
- Imp: “Refresh All UniFi HS4 Features” includes client tracking features
- Imp: Info messages in HS4 log from UniFi Network now optional
- Fix: UniFi Protect deserialization errors for versions < 2.x
- Fix: Client tracking Status/Graphic update for new UniFi devices
- Fix: Switch single/multiple client properties
- Fix: Force SSL 1.2 (for Windows 7 support)
- New: Replace UniFi device
- New: Enable/Disable ALL features for ALL devices
- Fix: Custom Network API call without Result feature could crash plugin
- Fix: Certificate error on Linux
- Fix: Single core CPU calculation
- Imp: Websockets code rewritten (no longer using websocket-sharp.dll)
- New: Support for Smart Sensor
- Imp: Smart Flood Light features
- Imp: Detection of added (adopt) and removed (forget) Network devices
- Fix: Add new system with Norwegian date/time format
- New: Line Crossing Person and Vehicle detection
- New: Support Floodlight motion detection
- New: Network and Protect state
- New: Support Unifi Protect 2.1
- Fix: Rename Unifi to UniFi wherever possible
- Fix: OutOfMemoryException errors
- New: Support for Power Strips
- New: Support for Package smart detection
- New: Support for Smart Chime
- Imp: ViewPort Live views refresh
- Imp: Detection of added and removed Protect devices
- Fix: ViewPort restart
- Fix: ViewPort Live View feature created at startup
- Fix: Some initial values not set after feature enablement
- Fix: “Do not set Image directly” error
- Fix: Celsius/Fahrenheit switch for console features
- New: Raid storage metrics and health added
- Fix: Client functions (forget, kick, block etc) not working for some configurations
- Fix: Instability after network/protect firmware update
- New: Custom API event action for Unifi Network
- Fix: Failed to get image (“Image failure” and “404 not found”)
- New: LED power/color/brightness event action
- Fix: Large Object Heap causing Insufficient memory errors
- Fix: Issue with Led color feature (Linux)
- Imp: Changed camera recording options “Motion” and “Smartdetect” to “Detections” in line with Protect 1.20.0
- New: Mark devices with private/random Mac addresses
- New: Storage metrics
- New: LED brightness and LED color for APs
- New: Optionally use port names from Unifi controller
- Fix: Wrong status when upgrading Protect firmware
- Fix: Remove Port # Transmit/Receive features from unsupported Routers
- Fix: Viewport Live Views refresh
- New: UDM Pro SE detection
- New: Separate buttons for Upgrade and Check firmware
- New: Switch features for UDM series
- New: PoE Off/Auto buttons
- Imp: All firmware upgrade/check functions renewed for more stability
- Imp: “Feature exist” caching for performance optimalization
- Imp: Added “Load avg x” to throttling settings
- Imp: Various performance improvements
- Fix: Removed unnecessary updating of “Up since” features
- Fix: Removed duplicate console/router features for UDM series
- New: Zoom support for the G4 Pro camera
- New: Wake-on-Lan (WOL) support incl. VLAN forwarding and SecureOn
- New: Persistent Client images
- Fix: Unifi OS firmware update stuck on “Updating...”
- Fix: Bogus “Connected To” feature after “enable multiple properties per client”
- Fix: Limit login rate (2 minutes)
- New: Camera snapshot feature
- New: Additional client tracking properties
- New: Events/alerts for Unifi Network
- New: Support for Unifi Network Power Plugs
- New: PoE power (wattage)
- New: Enable/Disable all properties per device or device type
- Imp: Only retrieve clients active in the last 7 days
- Fix: After device re-adoptions, actions stopped working
- Fix: If first PoE port is not the first port, numbering was incorrect
- Fix: “Forget” client did not remove the client from the plugin
- Fix: Orphan removal
- New: Support for Unifi Protect Floodlight
- Fix: UNVR device detection
- New: Current firmware
- New: Motion detect trigger time
- Fix: Auto-detect crash when using non-standard port
- Fix: Firmware updating status
- New: Detect and log 2FA attempts (2FA not supported)
- Imp: Plugin efficiency
- New: Set digital chime duration
- New: Toggle chime on/off (on restores last chime setting)
- New: Set Doorbell LCD from event action
- Fix: Blank setup pages
- Fix: Network/Protect firmware status
- Fix: UCKG2 and UNVR device detection
- Fix: LCD settings for some Doorbell firmware versions
- New: Doorbell chime control
- New: Doorbell LCD control
- New: Last 20 Motion/Ring/Person/Vehicle images
- Fix: Internet status for some Access Points
- Fix: Reconnection after hard disconnect
- New: Unifi Viewport support
- New: UDM as router type added
- New: Change name of Unifi system in setup
- New: Overrule default port number
- Fix: Root device not removed when last feature is removed
- Fix: No clean-up of old motion images
- Fix: Failure to retrieve images on some camera types
- Fix: Crash when Unifi Protect is not installed on UnifiOS
- Fix: Crash on Linux installations
- Fix: Missing temperature icons on Linux
- Fix: System instability when a Unifi device is enabled as a tracking device
- New: Real time ring detection, and last ring feature improvements
- New: Snapshots of motion, person, vehicle and ring detection
- Imp: Motion detection, should be a tad faster
- Fix: Crash during reboot of a Unifi device
- Fix: Creation of port # features
- Fix: Creation of duplicate features
- New: Throttling for memory, CPU, temperature, transmit, receive and experience features
- New: Last ring feature for G4 Doorbell
- Imp: Code and performance optimization
- Fix: Unnecessary updating of all features
- Fix: Decimals in CPU load
- Fix: Port # features not being created
- New: Support for multi-site configuration
- New: Unifi OS, Unifi Network and Unifi Protect firmware feature (Unifi OS only)
- New: Upgrade device firmware
- New: Fahrenheit support
- New: Forget client (setup page)
- New: Camera LED feature
- New: Camera IR Led feature
- New: Camera IR Led sensitivity feature
- New: Camera HDR feature
- New: Camera High FPS feature
- Imp: Site status (setup page)
- Imp: Sort client tracking list (name, hostname, mac)
- Imp: Use mac address if device name is not available
- New: Support for non-UnifiOS devices (previous gen Cloud Key and Software Controller)
- New: Support for Unifi Cloud Key Gen2 (non Plus)
- New: Support for Unifi Protect Network Video Recorder
- New: Auto detection of device type and supported apps
- New: Device enable/disable feature
- New: PoE port cycle feature
- New: controller and device firmware feature
- New: device satisfaction feature
- New: Number of clients feature
- New: Number of users feature
- New: Number of guests feature
- New: Internet status feature
- New: Unifi network Wifi feature (UnifiOS only)
- New: Unifi network Health label and score feature (UnifiOS only)
- New: Remove orphaned devices and tracking clients
- Imp: Moved device LED functions to own feature
- Imp: Moved device Locating functions to own feature
- Imp: Session refresh when expired
- Imp: Startup performance
- Imp: Limit the number of configured clients to 5000
- Fix: Crash on client tracking
- Fix: Unknown device images
- Fix: Device config page (JSON view)
- Initial version
