Clients
    Clients
    First, thank you so much for this plug in, I have been hoping to see a HS4 version for the unifi line.
    I am using a gen2 plus, and it seems to be working very well, but one question, should I see a Device out there for any Clients that I set to track?
    HS Install Date: Feb. 16, 2007
    HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
    WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
    Yes, absolutely. Every device you enable in the settings should create a feature below the "UnifiClients" root device.
    Filter on the category "Unifi" to see if the feature is being created. If not, we should investigate what is happening!
    stefxx
      I have one for clients but it wasn't there instantly like the other devices... it either needed some time to build or a page refresh; the next time I opened the browser, it was there. This was using Chrome.
        Thanks RGMessick ! It should be (nearly) instant... so I would guess a refresh issue.
        stefxx
          In my case enabling tracking will result in a critical disconnect error. Ending up that the plug-in load remotely when restarting.
          John
            Auch... not good. Let me look into this.
            stefxx
              Decided to stop and start the plugin, it created the Clients device, but nothing under that...then crashed. Now whenever I try to start it, it disconnects a couple seconds later and keeps re-trying.
              Went ahead and removed the plugin, and reinstalled, still disconnects, cant even get in to settings anymore.
              Tried both the .0 version and the beta .3
              Uninstalled the plugin, deleted all the files on my server, reinstalled and it works until I restart again...well it works in that it starts up, monitors cameras and other settings, but still no clients. This time I was able to get debug turned on, but I don't seem to see much more detail. This is from the 4.0.1.0 version currently.
              1/22/2021 2:58:36 PM
              HomeSeer
              Info
              Plugin Unifi with ID: Unifi and Instance: has disconnected
              1/22/2021 2:58:33 PM
              HomeSeer
              Starting Plug-In
              Plugin Unifi started successfully in 15 milliseconds
              Unifi
              Info
              Initialization of Unifi version 4.0.1.0 complete
              HomeSeer
              Starting Plug-In
              Initializing plugin Unifi ...
              HomeSeer
              Starting Plug-In
              Unifi loaded in 15071 milliseconds
              1/22/2021 2:58:18 PM
              HomeSeer
              Info
              Plugin Unifi with instance Unifi has connected. IP:127.0.0.1:51972
              HomeSeer
              Warning
              I/O interface Unifi is down, executable is not running, restarting ...
              1/22/2021 2:57:50 PM
              HomeSeer
              Info
              1/22/2021 2:57:48 PM
              HomeSeer
              Starting Plug-In
              Plugin Unifi started successfully in 13 milliseconds
              Unifi
              Info
              HomeSeer
              Starting Plug-In
              HomeSeer
              Starting Plug-In
              Unifi loaded in 15017 milliseconds
              1/22/2021 2:57:33 PM
              HomeSeer
              Info
              Plugin Unifi with instance Unifi has connected. IP:127.0.0.1:51933
              HomeSeer
              Warning
              1/22/2021 2:57:05 PM
              HomeSeer
              Info
              1/22/2021 2:57:02 PM
              HomeSeer
              Starting Plug-In
              Plugin Unifi started successfully in 20 milliseconds
              Unifi
              Info
              HomeSeer
              Starting Plug-In
              HomeSeer
              Starting Plug-In
              Unifi loaded in 15078 milliseconds
                Hi! Sorry about this. I am working on a fix. In the meantime, you can stop the plugin, open the Unifi.ini and remove the "Clients" section. Than start the plugin again. That should get the plugin running again.
                stefxx
                  Fix is available: https://forums.homeseer.com/forum/hs...2-beta-4-1-0-4
                  stefxx
                    Fix confirmed.
                    John
