Hi, This looks a great plugin but it only half works and I cannot find out how to set it up. I am only using the Unifi Wifi.
I can see some details but it is clear from the status and logs it is not properly cpnfigured somewhere.
Is there a readme I havent found about how to setup the unifi to work and then the plugin to match? I appologise if I missed it, a link in this Forum would be great!
This is what I get:
Thread started
Unifi System disconnected - what is this - surely it should be connected and how do I fix this?
Unifi Network connected - I dont have any unifi switches as I already have Netgear.
Unifi Protect disconnected
What does the above mean?
I cannot see how I am meant to configure the software controller to allow access - or do I just use the web portal information? If I do I dont see all the wifi AP MAC details. only one out of three. I had to manually edit this but it consistantly does not populate this properly.
1. Access Point: e0:63:da:cc:8b:83
2. Access Point
3. Access Point
Enable Unifi OS - Enabling this seems to break authoriation - what does it do?
Enable Unifi Network - Enabled
Enable Unifi Protection - I dont have this but tried enabling it.
In the unifi setup I changed this from the default url to this and it seemed to help, should it make a difference?
Controller Configuration
Controller Hostname/IP: 192.168.1.20
( it was example-domain.ui.com)
In the logs I also see this:
0,"guest-ra0-rx_dropped":0.0,"guest-rai0-rx_dropped":0.0,"user-rai0-rx_dropped":20122.0,"user-ra0-rx_dropped":29.0,"user-rx_dropped":20151.0,"guest-rx_dropped":0.0,"ra0-rx_dropped":29.0,"rai0-rx_dropped":20122.0,"rx_dropped":20151.0,"guest-ra0-rx_crypts":0.0,"guest-rai0-rx_crypts":0.0,"user-rai0-rx_crypts":0.0,"user-ra0-rx_crypts":0.0,"user-rx_crypts":0.0,"guest-rx_crypts":0.0,"ra0-rx_crypts":0.0,"rai0-rx_crypts":0.0,"rx_crypts":0.0,"guest-ra0-rx_frags":0.0,"guest-rai0-rx_frags":0.0,"user-rai0-rx_frags":0.0,"user-ra0-rx_frags":0.0,"user-rx_frags":0.0,"guest-rx_frags":0.0,"ra0-rx_frags":0.0,"rai0-rx_frags":0.0,"rx_frags":0.0,"guest-ra0-tx_packets":0.0,"guest-rai0-tx_packets":0.0,"user-rai0-tx_packets":504459.0,"user-ra0-tx_packets":341412.0,"user-tx_packets":845871.0,"guest-tx_packets":0.0,"ra0-tx_packets":341412.0,"rai0-tx_packets":504459.0,"tx_packets":845871.0,"guest-ra0-tx_bytes":0.0,"guest-rai0-tx_bytes":0.0,"user-rai0-tx_bytes":6.11599823E8,"user-ra0-tx_bytes":1.3854046E7,"user-tx_bytes":6.25453869E8,"guest-tx_bytes":0.0,"ra0-tx_bytes":1.3854046E7,"rai0-tx_bytes":6.11599823E8,"tx_bytes":6.25453869E8,"guest-ra0-tx_errors":0.0,"guest-rai0-tx_errors":0.0,"user-rai0-tx_errors":0.0,"user-ra0-tx_errors":0.0,"user-tx_errors":0.0,"guest-tx_errors":0.0,"ra0-tx_errors":0.0,"rai0-tx_errors":0.0,"tx_errors":0.0,"guest-ra0-tx_dropped":0.0,"guest-rai0-tx_dropped":0.0,"user-rai0-tx_dropped":0.0,"user-ra0-tx_dropped":0.0,"user-tx_dropped":0.0,"guest-tx_dropped":0.0,"ra0-tx_dropped":0.0,"rai0-tx_dropped":0.0,"tx_dropped":0.0,"guest-ra0-tx_retries":0.0,"guest-rai0-tx_retries":0.0,"user-rai0-tx_retries":49198.0,"user-ra0-tx_retries":0.0,"user-tx_retries":49198.0,"guest-tx_retries":0.0,"ra0-tx_retries":0.0,"rai0-tx_retries":49198.0,"tx_retries":49198.0,"guest-ra0-mac_filter_rejections":0.0,"guest-rai0-mac_filter_rejections":0.0,"user-rai0-mac_filter_rejections":0.0,"user-ra0-mac_filter_rejections":0.0,"user-mac_filter_rejections":0.0,"guest-mac_filter_rejections":0.0,"ra0-mac_filter_rejections":0.0,"rai0-mac_filter_rejections":0.0,"mac_filter_rejections":0.0,"gues t-ra0-wifi_tx_attempts":0.0,"guest-rai0-wifi_tx_attempts":0.0,"user-rai0-wifi_tx_attempts":553657.0,"user-ra0-wifi_tx_attempts":341416.0,"user-wifi_tx_attempts":895073.0,"guest-wifi_tx_attempts":0.0,"ra0-wifi_tx_attempts":341416.0,"rai0-wifi_tx_attempts":553657.0,"wifi_tx_attempts":895073.0,"gues t-ra0-wifi_tx_dropped":0.0,"guest-rai0-wifi_tx_dropped":0.0,"user-rai0-wifi_tx_dropped":1099.0,"user-ra0-wifi_tx_dropped":0.0,"user-wifi_tx_dropped":1099.0,"guest-wifi_tx_dropped":0.0,"ra0-wifi_tx_dropped":0.0,"rai0-wifi_tx_dropped":1099.0,"wifi_tx_dropped":1099.0,"bytes":1.1 91245543E9,"duration":2348000.0,"user-rai0-rai0-5f38fa26df011e1a341ddea4-rx_packets":280645.0,"user-rai0-rai0-5f38fa26df011e1a341ddea4-rx_bytes":2.5731188E7,"user-rai0-rai0-5f38fa26df011e1a341ddea4-rx_dropped":20122.0,"user-rai0-rai0-5f38fa26df011e1a341ddea4-tx_packets":504459.0,"user-rai0-rai0-5f38fa26df011e1a341ddea4-tx_bytes":6.11599823E8,"user-rai0-rai0-5f38fa26df011e1a341ddea4-tx_retries":49198.0,"user-rai0-rai0-5f38fa26df011e1a341ddea4-wifi_tx_attempts":553657.0,"user-rai0-rai0-5f38fa26df011e1a341ddea4-wifi_tx_dropped":1099.0,"user-ra0-ra0-5f6fe2d96f87ca22ecd2159c-rx_packets":629806.0,"user-ra0-ra0-5f6fe2d96f87ca22ecd2159c-rx_bytes":5.40060486E8,"user-ra0-ra0-5f6fe2d96f87ca22ecd2159c-tx_packets":341412.0,"user-ra0-ra0-5f6fe2d96f87ca22ecd2159c-tx_bytes":1.3854046E7,"user-ra0-ra0-5f6fe2d96f87ca22ecd2159c-wifi_tx_attempts":341416.0,"user-ra0-ra0-5f6fe2d96f87ca22ecd2159c-rx_errors":29.0,"user-ra0-ra0-5f6fe2d96f87ca22ecd2159c-rx_dropped":29.0,"user-rai0-rai0-5f38fa26df011e1a341ddea4-rx_errors":6.0}},"tx_bytes":625453869,"rx_bytes":565791674," bytes":1191245543,"vwireEnabled":true,"uplink_table":[],"num_sta":9,"user-num_sta":9,"user-wlan-num_sta":9,"guest-num_sta":0,"guest-wlan-num_sta":0,"x_has_ssh_hostkey":true}]}
[UniFi-edgworks] Login: https://192.168.1.20:8443/api/login, Method: POST, Payload: {"username":"MarkEdgerton","password":"--secret--"}
[UniFi-edgworks] Login: {"meta":{"rc":"ok"},"data":[]}
[UniFi-edgworks] UP NVRs: https://192.168.1.20:8443/api/bootstrap
[UniFi-edgworks] UP connection failure: The remote server returned an error: (401) Unauthorized.
The password is correct so what is going wrong. As I say it looks to half work.
Many thanks,
Mark
This is what I get:
Thread started
2. Access Point
3. Access Point
Many thanks,
Mark
