Plugin very high CPU usage
    Stefan,
    can you check if you have a loop, the plugin cpu usage vary between 25-50% of the CPU usage, all other plugin are less then 1%
    Hi, that is odd. If I look at my own production system, this is what I see:
    I used the resource monitor as that will give you Average CPU.
    I am getting a lot of data that needs to be processed, so a little more that other plugins is expected. But not 25-50%.
    Not sure where to look for issues without being able to reproduce it...
    stefxx
      this is what I have, how can I help debug this
      Click image for larger version  Name:	Untitled.png Views:	0 Size:	13.9 KB ID:	1454675
        Not good
        Does restarting the plugin help? Is is right from the start, or only after some time? Is it increasing with time?
        stefxx
          From the start high peak 15 then go 25-35 stable at that
            After some going back and forth with Don, the latest beta has two improvements:
            • I fixed a rare situation were it would update every feature every time, even if unchanged
            • I implemented throttling for features that update too frequent (every few seconds or faster)
            The throttling is configurable in the setup, and is valid for "Memory", "CPU", "Temperature", "Transmit", "Receive" and "Experience" features.
            If you experience high load, please test this version and give me some feedback.
            Thanks!
            stefxx
              Thank you Stefan,
              the last version did improve by far.
