Html parsing error in setup
    I guys,
    the plugin was working great for the past weeks and now when i try to go in setup i always get this
    Problem parsing HTML: (110,10) : error : Exceeding number of iteration limit `10000` for statement: for item in items ... end {{includefile '/bootstrap/css/page_common.css'}} {{includefile 'header.html'}} {{includefile 'navbar.html'}}
    {{ tabs=plugin_function 'Unifi' 'SettingsGetTabs' [] }}{{ for tab in tabs }} {{ if tab[1]=="True" }}
    {{ else }}
    {{ end }}
    {{ items=plugin_function 'Unifi' 'SettingsGetTab' [tab[0]] }} {{ for item in items }} {{ item }} {{ end }}
    {{ end }}
    {{includefile 'bootstrap/js/page_common.js'}} {{ items=plugin_function 'Unifi' 'SettingsGetScripts' [] }} {{ for item in items }} {{ item }} {{ end }}
    I tried with edge, chrome, firefox samething
    I tried to reboot also
    any idea
    Hi! Sorry you are running into issues. I've seen this before, it is because there are more than 10.000 clients in the Unifi history.
    Can you check in the Unifi Network, Clients, click "All configured clients" (top right), and click "All" (top middle). Then scroll down and check the number of clients.
    In the previous situation it was being caused by a old hack on the system. It can also be caused by simply a lot of different clients over the years, and they seem to be included in backups as well. Either way, it is reason for concern and should definitely be checked.
    Recent versions of the plugin have a hard limit on the number of clients that should be retrieved (I believe 5000), what version of the plugin are you running?
    stefxx
      like 2500 is there a way to clear this
      plugin is
      unifi: 4.0.4.0
      unifi network 6.0.45
      protect 1.17.3
      thx
        Here is a way to purge it: https://help.ui.com/hc/en-us/articles/204911424#4.5
        stefxx
          Cool i will try that thx
          Envoyé de mon Pixel 2 XL en utilisant Tapatalk
