4.0.7.7: Unifi Clients - Not Firing When Client Goes Online
  • stefxx
    Here are some tips: https://forums.homeseer.com/forum/hs...atus-explained
  • stefxx
    Hi! Yes, this makes sense. For Offline, there is only a single status, "Offline". But when the device becomes online, the status depends on the device (switch or access point) it is connected to. the "Online" status basically means that the plugin sees the client as connected, but doesn't know to which device. Which should never happen anyway.
    Best to test against "equal to Offline" and "Not equal to Offline".
    I will create a sticky explaining this, as I've seen the question before and I understand the confusion.
    And thanks for the kind words! Let me know if you have any other questions.
  • niewski
    started a topic 4.0.7.7: Unifi Clients - Not Firing When Client Goes Online
    I'm using the latest version of UDMP firmware. I have a it configured to monitor my cell phone. When the cellphone goes offline, I get an event and everything works well. When it goes online, I never see the event. The Plugin | Unifi Clients goes green and works, but my events do not fire.
    I have the following:
    IF
    Plugin Unifi Unifi Clients Jeff's Phone changes and becomes Online
    THEN
    Speak Jeff's phone detected
    Same logic works for when it goes Offline.
    BTW - GREAT job on the plugins - I seem to be buying all of your wares....
