DPI Enable/disable
    DPI Enable/disable
    Hi Stef,
    is there anyway that we can enable/disable DPI from Homeseer ?
    i have some DPI restrictions and i want to switch them on @ 20:00 and release then the next morning.
    So i can implement some kind of parental control in de UDM Pro
    Hi!
    I have never used DPI, so this is new ground for me. Are you trying to enable/disable DPI all-together, or individual settings?
    Let me know and I'll look into it.
    stefxx
      Hi Stef,
      in unifi you can set "Enable DPI" ON/Off
      but in the Tab DPI restriction you can create several restiction groups, these restrictions can also be Enabled / Disabled.
      if we can Use the overall "Enable DPI" ON/Off it would be ok.
        I've looked into this, but since this is part of the network configuration, for now I decide not to implement it. Reason is simple and the same for other configuration options: I need to poll to get latest status. All other functionality is based on websockets, and is being "pushed" to the plugin. Also, I think not many users are interested and it means quite a change in the plugin.
        stefxx
