Anyone willing to test?
    #61
    Originally posted by stefxx View Post
    I've seen the plugin crash when updating devices. Messing with the network configuration on a live system will always cause unpredictable results. However, it should restart and recover off course. If all devices completed the upgrade and the plugin still fails to start, something is really wrong!!
    That is exactly the case.
    RJ_Make On YouTube
      #62
      Cli output sent
      RJ_Make On YouTube
        #63
        Thanks. Can you try beta 12? A bit of a long shot. If it still crashes, can you send me the CLI output again?
        stefxx
          #64
          The PI has an indicator of .13. Same results, sent cli logs
          RJ_Make On YouTube
            #65
            PI will not update UDMB OS or Network using the upgrade button.
            RJ_Make On YouTube
              #66
              Design Change Suggestion: A new debug file created whenever the option is turned off. I would have had a debug file to send, but it was 28 Gigs big. ( I turned it off then back on thinking a new, versioned file would be created).
              RJ_Make On YouTube
                #67
                Mmmm.. I just upgraded the Network Application to 6.3.something using the plugin.
                stefxx
                  #68
                  Neither worked for me, and I tried at least twice on both. (over a ~15 min wait)
                  RJ_Make On YouTube
                    #69
                    Interesting. I wonder if Ubiquiti changed the upgrade process for the UDM - Again
                    If they keep changing it, I might remove this feature all together. I can't keep up. Let's wait if there is an update for the UCKG2 as well soon so I can see this for myself.
                    Device firmware upgrades are more stable luckily.
                    stefxx
                      #70
                      Just checking, you are using the latest beta right? 4.0.12.16?
                      stefxx
                        #71
                        Yes
                        RJ_Make On YouTube
                          #72
                          Hi ServiceXp , I've found a little something on the Network/Protect firmware upgrade since the latest UnifiOS update. Made a small adjustment in beta 4.0.13.1.
                          I only tested it once (there was a beta update for both Network and Protect), but I am not sure if I fixed it for all situations. If you have the chance, let me know if this improves anything for you.
                          Thanks!
                          stefxx
                            #73
                            AFAIK, everything (except UDM Updates) has been working well. What was the PI issue?
                            RJ_Make On YouTube
