rnbHydra is a plugin designed to bring together the power of two of the most advanced systems for the smarthome: Hydrawise and HomeSeer. Hydrawise is the Industry-leading technology by Hunter Industries giving you the most powerful Wi-Fi irrigation control solution on the market. With this plugin, you can now integrate Hydrawise into your smart home giving you total control over your irrigation.
Link to HomeSeer Store: https://shop.homeseer.com/collection...plugin-for-hs4
Userguide is here: rnbHydra - Userguide
Overview video is here: https://youtu.be/pDq7OAXg5SA
Setup video is here: https://youtu.be/gVMJPUDM20s
Support/Issues/Bugs/Enhahcements
I utilise a simple issue tracking system for issues/bugs/enhancements with the main reason to ensure I do not miss any issues raised.Issues can be raised from directly within the plugin (preferred method) or issues/bugs can be raised directly at this link.
Version History
- Status reporting of your irrigation controller and zones
- Start/Stop/Suspend your irrigation
- Allows Homeseer to trigger events on Hydrawise events & errors
- HomeSeer HS4 or HS4PRO
- Hydrawise Wi-Fi Controller (by Hunter)
- Internet Access (both HS4 and Hydrawise)
Version History
- 4.0.4.1 (17 Aug 2021)
- Error in GraphQL accepting suspension date/time format
- Error in event: Manage zone - suspend
- 4.0.0.10 (9 Dec 2020)
- Bugfix: Updated API call (change in API causing plugin to crash and not respond)
- 4.0.0.4 (26 Oct 2020)
- Testfix: Test fix for "unauthorized" loop error causing plugin to go into endless loop
