Plugin for IKEA TRÅDFRI smart home devices Introduction / Configuration
This is a sticky topic.
    My plugins: Click image for larger version  Name:	ikea_64.png Views:	0 Size:	2.1 KB ID:	1421180​​​ Click image for larger version  Name:	Square64.jpg Views:	0 Size:	2.8 KB ID:	1421181​​​ Click image for larger version  Name:	Bond64.png Views:	0 Size:	5.1 KB ID:	1421176​​​ Click image for larger version  Name:	Sonoff64.png Views:	0 Size:	5.6 KB ID:	1421182​​​ Click image for larger version  Name:	Shelly128.png Views:	0 Size:	21.5 KB ID:	1471335 ​​​ Click image for larger version  Name:	gates  - 3.jpg Views:	0 Size:	93.7 KB ID:	1423325​​
    AK IKEA AKSquare AKBond AKSonoff AKShelly AKRemootio
ID:	1473119 Click image for larger version  Name:	AKEnphaseEnvoy64.png Views:	0 Size:	8.7 KB ID:	1421179​​​ Click image for larger version  Name:	AKGoogleCast64.png Views:	0 Size:	1.5 KB ID:	1421178​​​ Click image for larger version  Name:	HS4500 - Copy.png Views:	0 Size:	32.0 KB ID:	1471334 ​​​ Click image for larger version  Name:	Quantum128.jpg Views:	0 Size:	11.3 KB ID:	1471333 ​​​ Click image for larger version  Name:	AKHeatmiserNeo64.jpg Views:	0 Size:	2.1 KB ID:	1421185​​​ Click image for larger version  Name:	AKTracdown500 - New.png Views:	0 Size:	300.3 KB ID:	1423326​​
    AKWeather AKEnphaseEnvoy AKGoogleCast AKGoogleCalendar AKSmartDevice AKHeatmiserNeo AKTraccar
    IKEA Smart lighting
    I don't think IKEA needs introducing, but my plugin is for controlling IKEA smart home devices via HomeSeer
    https://shop.homeseer.com/products/a...plugin-for-hs4
    Click image for larger version  Name:	IKEA-Still-1592x796-800x400.jpg Views:	0 Size:	32.4 KB ID:	1448478
    Click image for larger version  Name:	Ikea-Kadrilj-und-Fyrtur.png Views:	1 Size:	322.0 KB ID:	1448482
    Click image for larger version  Name:	tradfri-driver-for-wireless-control-grey.jpg Views:	1 Size:	32.1 KB ID:	1448483
    Screenshots:
    Click image for larger version  Name:	GridView.jpg Views:	0 Size:	125.9 KB ID:	1448486
    Click image for larger version  Name:	Main Screenshot.jpg Views:	60 Size:	186.4 KB ID:	1455520
    Click image for larger version  Name:	devices.png Views:	60 Size:	73.1 KB ID:	1455521
    Configuration
    After installing the plugin you need to configure the Gateway -
    1. After a few seconds the plugin should discover the Tradfri Gateway (using mDNS/Zeroconf discovery) and create root HS device.
    Note 1: If discovery doesn't find the Gateway:
    - on Linux google for Avahi troubleshooting
    - on Windows the best Zeroconf is Bonjour Print Services for Windows - install the service and after restarting the plugin it should use it for discovery (Mono.Zeroconf)
    Note 2: if mDNS/Zeroconf Discovery still doesn't work for some reason - you can add new device manually
    2. Enter Ikea Gateway Key (found on the bottom of Gateway).
    3. Plugin should generate "app name" and request "app key" automatically.
    4. That's it. AK IKEA plugin will discover the devices and create HS devices.
    Click image for larger version  Name:	settings.png Views:	0 Size:	64.6 KB ID:	1455522
      Note on Update rate settings:
      1. Update rate for the Bridge (Gateway):
      Controls scan time for new devices / groups / moods (scenes)
      If you don't plan adding new devices - it can be disabled (set to 0)
      2. Update rate for the Groups:
      Similar to the Bridge - scanning for new devices and moods (scenes) in the group
      3. Update rate for the Lights:
      The light devices support Observation (immediate notifications), but just in case I also scan them for changes.
      Can be disabled also (set to 0).
        Created ROOT devices:
        1. The Gateway (Bridge)
        2. Lights
        3. LED Drivers
        4. Groups
        5. Remote Controls
        For each RGB Light:
        1. Brightness slider, On/Off
        2. Color devices: Hue/Sat/X/Y
        3. Predefined (named) Tradfri colors
        4. Custom RGB color - note that Tradfri protocol doesn't support RGB setting, so the plugin converts the custom color to Color XY - which may produce slight variation in colors
        5. Transition time (ramp rate) - separate for the Brightness and the Color changes
        For White spectrum lights:
        There's no Color controls,
        1. only color temperature (if supported) - WarmGlow, WarmWhite, CoolWhite and
        2. related color temperature (in Mireds) - i.e. CoolWhite = 250M, WarmGlow = 454M
        For each Group:
        1. Similar devices to each group member
        2. Mood (Scene) i.e. Everyday, Relax, Focus (scenes are created in Ikea Home app)
        For Tradfri remote:
        1. Battery level
          Ver 4.0.0.6 (BETA) - Improved connection / reconnection to IKEA hub
