Upgrading from HS3 version
    #16
    Please let me know if you need any extra logging
      #17
      Thank you.
        #18
        It may be due to power or network outages - I noticed if the gateway ever reboots for whatever reason, the plugin will start reporting the same error and never try to reconnect, until restarted...
          #19
          I have reconnect code, but it's really hard to reproduce. May be I try your suggestion restarting the gateway.
            #20
            I'm guessing reconnect code doesn't always trigger - sometimes it goes into this failure mode, where it receives "Tradfri Hub: Request failed[]" and never recovers or tries to reconnect. But sometimes it works, as I was shuffling my setup a bit and had to disconnect Tradfri Hub couple times and the plugin was able to recover/reconnect after that. I now have it connected to an UPS and it's been stable and working fine for a few days so far... But I'll keep an eye on it.
              #21
              My automation is also connected to UPS, so I never had these issues. But I'll test disconnecting manually.
                #22
                And it failed again...
                And after that it keeps on repeating Tradfri Hub: Retry: /15001/65539 and Tradfri Hub: Request failed[] : /15001
                Ver 4.0.0.6 (BETA) - Improved connection / reconnection to IKEA hub
                  #23
                  Thank you!
                    #24
                    Thank you!
                    Hopefully it fixes the problem
                      #25
                      I had previously tried to upgrade from HS3 to HS4 plugin with no success. I have just upgraded and it went perfectly. I disabled the HS3 version but did not delete the devices. Once the HS4 plugin had polled the devices all seems fine.
                      Thank you.
                        #26
                        Thank you.
                        I don't like upgrading from HS3 - there's too many things which can go wrong. I always start from scratch. But if it worked for you - good.
