When I installed the new version, it said I had to close the running plugin first. I interpreted this as the plugin will upgrade from the HS3 version. However, after installation it seems that the plugin didn't reuse the data and devices. All I have is the config page and it is stuck on auto discover, but nothing happens. The log shows two errors:
AK Ikea
Error
System.NullReferenceException: Objektreferanse er ikke satt til en objektforekomst. ved PluginLib.ControllerBase.ValueChanged(Int32 RefId, Double value, Nullable`1 oldval, Boolean myDevice, String ControlString)
AK Ikea
Error
[374]: ValueChanged(0): Objektreferanse er ikke satt til en objektforekomst.
Device 374 is a IKEA bulb that I tried to control to test if the plugin worked. It didn't. Other than that, there are no logging from the plugin, not even the installation is logged.
regards,
Dag-Inge
19.01.2021 22:00:01
AK Ikea
Error
19.01.2021 22:00:01
AK Ikea
Error
- Is the HS4 version supposed to do an upgrade when you have HS3 version?
- Did I do something wrong?
- Can I fix this without recreating all my IKEA devices and events?
regards,
Dag-Inge
