A status graphic with that value set already exists
    Do you know why i have all these warnings in the log?
    Can it be something like this
    https://forums.homeseer.com/forum/de...already-exists
      Didi it start after HS upgrade to 4.1.14?
      Because yesterday I had the same problem reported about AKBond plugin. https://forums.homeseer.com/forum/hs...already-exists
        Can you please post screenshot of the device configuration (Status/Graphics tab)
          Ver 4.0.0.13 (BETA) I made some adjustments for the StatusGraphics. But the changes affect only newly created devices.
          If you don't want to re-create the offending devices - you can manually adjust the Brightness range from 100 to 99:
Name:	Screenshot 2021-03-12 142505.jpg
            Yes it might have started after the 4.1.14 update. I will try to change the end value manually now first, to see if it is ok.
              It seems like changing the end value to 99 on dim, and on status graphic did the trick. No more error for now. Will watch it and see if anything else comes up.
                HST added more error checking in last update. Don't know if it's good or bad...
                  It's confirmed bug in HS4 https://github.com/HomeSeer/Plugin-SDK/issues/179
                    Since upgrading to 4.1.15.0 I am now seeing these errors in the log.
                    My end value is 100.
                    Is there anything else I can check?
                      4.1.15.0 is supposed to fix the problem, not create. Can you post the screenshot, "My end value is 100" is kind of hard to understand.
                          Thank you, but I mean the screenshot of Status/Controls/Graphics configuration
                              Did you read post #5?
                              Since HS 4.1.15.0 doesn't seem to fix the problem - you need to either delete the offending devices and restart the plugin, or change the graphics settings manually.
