A status graphic with that value set already exists
  • alexbk66
    Great
  • IanIreland
    The problem does now seem to have resolved - many thanks to all.
  • alexbk66
    Originally posted by IanIreland View Post
    Thank you - I've made a change, let's see what happens :-)
    It should work. Before HS was more forgiving, now they do have more checks (better later than never?)
  • IanIreland
  • brientim
    Click image for larger version  Name:	Ikea2.PNG Views:	0 Size:	319.4 KB ID:	1466424
    There is duplicate values in the screenshoot.
    Range 1-100 and single value 100
    Change Range from 1-100 to 1-99
    Waiting for the fix by HST may not be worth the wait.
  • alexbk66
    Did you read post #5?
    Since HS 4.1.15.0 doesn't seem to fix the problem - you need to either delete the offending devices and restart the plugin, or change the graphics settings manually.
  • IanIreland
  • alexbk66
    Thank you, but I mean the screenshot of Status/Controls/Graphics configuration
  • IanIreland
  • alexbk66
    Since upgrading to 4.1.15.0 I am now seeing these errors in the log.
    My end value is 100.
    Is there anything else I can check?
    4.1.15.0 is supposed to fix the problem, not create. Can you post the screenshot, "My end value is 100" is kind of hard to understand.
  • IanIreland
  • alexbk66
    It's confirmed bug in HS4 https://github.com/HomeSeer/Plugin-SDK/issues/179
  • alexbk66
    HST added more error checking in last update. Don't know if it's good or bad...
  • frankis78
    It seems like changing the end value to 99 on dim, and on status graphic did the trick. No more error for now. Will watch it and see if anything else comes up.
  • frankis78
    Yes it might have started after the 4.1.14 update. I will try to change the end value manually now first, to see if it is ok.
