Error somethimes after upgrade to HS4 version
    Hi,
    After I upgraded to the HS4 version I see often these error message after a event is run.
    3-20-2021 07:11:11
    AK Ikea
    Warning
    [6297] Overloop Gordijn: SetPosition - bridge is busy, skipping (0)
    With the HS3 version I have never seen this and events always working.
    When I get this error The event is not execute, sio the curtain stays closed.
    Before I installed the HS4 version I deleted all devices and the old plugin and started from zero.
    Antoon
    That's should be only within first 30 seconds after start-up
      This was happening this morning but HS was restarted yesterday evening, so it was not after start-up
        Please check logs for any messages, the plugin should have restarted, there's no other reason for the message
Name:	Screenshot 2021-03-20 203102.png
          This is the only message I see in the log adn that was when I restarted HS last night.
          The error message was exactly on the time the event was execute
          Time
          From
          Type
          Message
          3-20-2021 00:14:07
          HomeSeer
          Info
          Plugin AKIkea with instance AK Ikea has connected. IP:127.0.0.1:55535
            I still don't believe it's possible, but I could be wrong.
            In ver. 4.0.0.15 (BETA) I added extra logging, please try.
              Installed .15
              Let you know when something goes wrong
                Thank you
                  First time when I want to close my screen I get the same warning and screen stays open.
                  Second time after a minute or so it was working.
                    Hmm, but the first time in the log (15:45:12) is the plugin start-up time. I need to check.
                      Ok, found it, interesting, in Debug version it works as expected, but in Release the startup time is optimised to initialize only when you use it first time.
                      So in ver. 4.0.0.16 I added logging the startup time, so it's initialised on start-up properly.
                        Update to .16
                          NP
