Missing picture
    Missing picture
    Hi, i see there is an error in the log
    File does not exist: /home/pi/HomeSeer/html/AKIkea/WarmWhite.png
    Do you have this pic?
    I see that there is not any picture in this folder at all.
    Thanks.
    I generate the color icons at runtime, on Windows it's ok. I need to check on Linux...
      Actually, in some plugin version I added cleaning of the html folder (to delete generated html files on start-up) - but I was deleting all files in the folder.
      Then I fixed it to delete only html files, but I thought it should re-create the color icons? What plugin version BTW?
      If not, just extract attached zip.
        Yeah, it re-creates the color icons only when you delete and re-create the Ikea HS devices
          Ok great.
          Just a tip, i checked the Native Homeseer Philips Hue plugin, and they have it inside a image folder, maybe its good for you as well, to do the same structure
            Everybody do it differently. It doesn't matter if it works. Does it work?
              Yes it works now
              Thank you.
                Great
