Original Plugin for Shelly devices - Intro / Config / Screenshots [No MQTT]
This is a sticky topic.
    #31
    santoal what does it show on the device config page in HS? What Dimmer settings do you think is necessary to implement in HS? Definitely user/password.
      #32
      Dimmer control looks ok. This is what it shows for the dimmer control in HS. I would just use the Shelly app for settings. Perhaps fade rate and auto off/on timer if that is what you mean.
      Click image for larger version  Name:	pic.png Views:	53 Size:	133.9 KB ID:	1344332
        #33
        Hmm, there's no AKShelly tab? I will check...
        I think using "auto off/on timer" on Shelly defeats the purpose of automation system. But I'll think about other settings. Probably after my Dimmers arrive.
          #34
          Version 3.0.0.24 in BETA - continue on Shelly Dimmer and Shelly EM
          santoal please test
            #35
            We have control!
            Just a few issues:
            1) Off Status not showing correctly in HS3. Changes momentarily but then goes back to % dim value. I think because its re-reading the dim status % from Shelly which then overrides off. Pressing off does turn it off though.
            2) Can only seem to slide dim to 99% max in HS
            3) Temperature log error
            Dec-06 12:32:14 AM AK Shelly ERROR [746]: shellydimmer (SHDM-1): HandleDeviceStatus for (Ref: 749) F3A91D.Temperature (Unknown)
            Dec-06 12:32:14 AM AK Shelly [746]: shellydimmer (SHDM-1): *** {"wifi_sta":{"connected":true,"ssid":"Karoo Springs","ip":"192.168.1.164","rssi":-55},"cloud":{"enabled":true,"connected":true},"mqtt":{"conne cted":false},"time":"00:32","serial":3604,"has_update":false ,"mac":"CC50E3F3A91D","lights":[{"ison":false,"mode":"white","brightness":99}],"meters":[{"power":0.00, "is_valid":true, "timestamp":1575592334,"counters":[0.020, 0.015, 0.001],"total":95}],"inputs":[{"input":0},{"input":0}],"tmp":{"tC":46.24,"tF":115.23, "is_valid":"true"},"calib_progress":0,"overtemperature":fals e,"loaderror":false,"overload":false,"update":{"status":"idl e","has_update":false,"new_version":"20191127-095929/v1.5.6@0d769d69","old_version":"20191127-095929/v1.5.6@0d769d69"},"ram_total":39600,"ram_free":28232,"fs_siz e":233681,"fs_free":140560,"uptime":214656}
            Dec-06 12:32:14 AM AK Shelly [746]: shellydimmer (SHDM-1): Execute cmd: status
              #36
              Yeah, the problem is - I didn't want to create two HS devices - one for on/off, one for dim level. Tried to combine them in one. I'll think more... I don't like two separate devices...
              Shelly do have separate control for on/off and brightness - which is good. May be it makes sense to separate them?
                #37
                I think I fixed it. But can't submit BETA, their developers portal is misbehaving again...
                  #38
                  I think the way LIFEX UltraLighting 3 plugin implements dimmers works well. Having 1 device is good for things like integration with Alexa.
                  Click image for larger version  Name:	Capture.JPG Views:	0 Size:	26.0 KB ID:	1344800
                    #39
                    Can you please paste screenshot of status graphics config page for the device?
                      #40
                      When developers portal is fixed - version 3.0.0.26 in BETA should get closer.... Also includes Shelly EM, added Temperature and Input(s) HS devices for all Shelly devices.
                        #41
                        In the mean time... Since HST can't fix their portal. Attached the version 3.0.0.26.
                        You need to copy the zip file to "C:\Program Files (x86)\HomeSeer HS3\Updates3\Zips" and the updater_override.txt to the root HS installation.
                          #42
                          Installed. Still not working properly. Here is the dimmer page for other z-wave dimmers. There is a "Last" button which turns on the lights to the last dimmer setting.
                            #43
                            Scrap that. Update didn't install properly. Updates from Shelly web page to HS3 work ok. Turning off dimmer in HS3 has no effect and produces an error. I think a "last" button still makes sense as per previous post.
                            Dec-08 9:24:12 AM AK Shelly ERROR [758]: shellydimmer (SHDM-1): [SHDM-1] F3A91D (192.168.1.164): Execute '/light/0?brightness=0&turn=off': Status: 'Error' Error: 'Data at the root level is invalid. Line 1, position 1.' response: 'Bad brightness value!' code: 'BadRequest/Bad Request' ''
                            Dec-08 9:24:12 AM AK Shelly [758]: shellydimmer (SHDM-1): *** Bad brightness value!
                            Dec-08 9:24:12 AM AK Shelly [758]: shellydimmer (SHDM-1): Execute cmd: /light/0?brightness=0&turn=off
                            Dec-08 9:24:12 AM AK Shelly [758]: shellydimmer (SHDM-1): SetBrightness to 0
                              #44
                              Also I have a temp of 48 deg causing the warning symbol to appear. I assume 48 deg is ok still? Everything else working ok.
                                #45
                                Yeah, that's all good, I just reused the settings from Shelly H&T - where 40 deg is too much. I will change that. Or you can change the status graphic range yourself...
                                "Bad brightness value!" is an error returned from Shelly - which means it doesn't like brightness=0? Can you set brightness to 0 from Dimmer webpage?
                                I can add "Last=255". We'll see...
