4.0.0.33 Errors
This topic is closed.
    4.0.0.33 Errors
    Hi There,
    Just installed the beta to get the Uni temperatures, but seeing some issues in the logs:
    23/02/2021 11:13:32
    AK Shelly
    Error
    [641] 483FDA82BF81.shellyuni: Execute 'settings': Status: 'Error' (). Error: 'Unable to cast object of type 'RestSharp.JsonArray' to type 'System.Collections.Generic.IDictionary`2[System.String,System.Object]'.'. Response: '{"device":{"type":"SHUNI-1","mac":"483FDA82BF81","hostname":"shellyuni-483FDA82BF81","num_outputs":2},"wifi_ap":{"enabled":false,"s sid":"shellyuni-483FDA82BF81","key":""},"wifi_sta":{"enabled":true,"ssid":"I oT","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dn s":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_meth od":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt ": {"enable":false,"server":"192.168.33.3:1883","user":"","id": "shellyuni-483FDA82BF81","reconnect_timeout_max":60.000000,"reconnect_t imeout_min":2.000000,"clean_session":true,"keep_alive":60,"m ax_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","ena bled":true},"login":{"enabled":false,"unprotected":false,"us ername":"admin"},"pin_code":"uaiDqQ","name":null,"fw":"20201 124-093042/v1.9.0@57ac4ad8","factory_reset_from_switch":true,"discovera ble":false,"build_info":{"build_id":"20201124-093042/v1.9.0@57ac4ad8","build_timestamp":"2020-11-24T09:30:42Z","build_version":"1.0"},"cloud":{"enabled":true ,"connected":true},"timezone":"Europe/London","lat":51.414101,"lng":-1.318650,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":fals e,"tz_dst_auto":true,"time":"11:13","unixtime":1614078812,"a ctions":{"active":true,"names":["out_on_url","out_off_url","btn_on_url","btn_off_url","longp ush_url","shortpush_url","out_on_url","out_off_url","btn_on_ url","btn_off_url","longpush_url","shortpush_url","adc_over_ url","adc_under_url","ext_temp_over_url","ext_temp_under_url ","ext_temp_over_url","ext_temp_under_url","ext_temp_over_ur l","ext_temp_under_url","ext_temp_over_url","ext_temp_under_ url","ext_temp_over_url","ext_temp_under_url","ext_hum_over_ url","ext_hum_under_url"]},"hwinfo":{"hw_revision":"prod-202008", "batch_id":0},"mode":"relay","longpush_time":800,"relays ":[{"name":null,"appliance_type":"General","ison":false,"has_ti mer":false,"default_state":"off","btn_type":"toggle","btn_re verse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false,"sc hedule_rules":[]},{"name":null,"appliance_type":"General","ison":false,"has_ timer":false,"default_state":"off","btn_type":"toggle","btn_ reverse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false," schedule_rules":[]}],"adcs":[{"range":12,"relay_actions":[{"over_threshold":0,"over_act":"disabled","under_threshold": 0,"under_act":"disabled"},{"over_threshold":0,"over_act":"di sabled","under_threshold":0,"under_act":"disabled"}]}],"ext_sensors":{"temperature_unit":"C"},"ext_temperature":{" 0":[{"overtemp_threshold_tC":0.0,"overtemp_threshold_tF":32.0,"u ndertemp_threshold_tC":0.0,"undertemp_threshold_tF":32.0,"ov ertemp_act":"disabled","undertemp_act":"disabled","offset_tC ":0.0,"offset_tF":0.0},{"overtemp_threshold_tC":0.0,"overtem p_threshold_tF":32.0,"undertemp_threshold_tC":0.0,"undertemp _threshold_tF":32.0,"overtemp_act":"disabled","undertemp_act ":"disabled","offset_tC":0.0,"offset_tF":0.0}]},"ext_humidity":{}}'. Code: 'OK' (OK)
    23/02/2021 11:13:33
    AK Shelly
    Info
    Saved device: shellyflood (SHWT-1), id: C8B268, url: http://172.16.20.142/
    23/02/2021 11:13:35
    AK Shelly
    Error
    [641] 483FDA82BF81.shellyuni: Execute 'settings': Status: 'Error' (). Error: 'Unable to cast object of type 'RestSharp.JsonArray' to type 'System.Collections.Generic.IDictionary`2[System.String,System.Object]'.'. Response: '{"device":{"type":"SHUNI-1","mac":"483FDA82BF81","hostname":"shellyuni-483FDA82BF81","num_outputs":2},"wifi_ap":{"enabled":false,"s sid":"shellyuni-483FDA82BF81","key":""},"wifi_sta":{"enabled":true,"ssid":"I oT","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dn s":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_meth od":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt ": {"enable":false,"server":"192.168.33.3:1883","user":"","id": "shellyuni-483FDA82BF81","reconnect_timeout_max":60.000000,"reconnect_t imeout_min":2.000000,"clean_session":true,"keep_alive":60,"m ax_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","ena bled":true},"login":{"enabled":false,"unprotected":false,"us ername":"admin"},"pin_code":"uaiDqQ","name":null,"fw":"20201 124-093042/v1.9.0@57ac4ad8","factory_reset_from_switch":true,"discovera ble":false,"build_info":{"build_id":"20201124-093042/v1.9.0@57ac4ad8","build_timestamp":"2020-11-24T09:30:42Z","build_version":"1.0"},"cloud":{"enabled":true ,"connected":true},"timezone":"Europe/London","lat":51.414101,"lng":-1.318650,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":fals e,"tz_dst_auto":true,"time":"11:13","unixtime":1614078815,"a ctions":{"active":true,"names":["out_on_url","out_off_url","btn_on_url","btn_off_url","longp ush_url","shortpush_url","out_on_url","out_off_url","btn_on_ url","btn_off_url","longpush_url","shortpush_url","adc_over_ url","adc_under_url","ext_temp_over_url","ext_temp_under_url ","ext_temp_over_url","ext_temp_under_url","ext_temp_over_ur l","ext_temp_under_url","ext_temp_over_url","ext_temp_under_ url","ext_temp_over_url","ext_temp_under_url","ext_hum_over_ url","ext_hum_under_url"]},"hwinfo":{"hw_revision":"prod-202008", "batch_id":0},"mode":"relay","longpush_time":800,"relays ":[{"name":null,"appliance_type":"General","ison":false,"has_ti mer":false,"default_state":"off","btn_type":"toggle","btn_re verse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false,"sc hedule_rules":[]},{"name":null,"appliance_type":"General","ison":false,"has_ timer":false,"default_state":"off","btn_type":"toggle","btn_ reverse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false," schedule_rules":[]}],"adcs":[{"range":12,"relay_actions":[{"over_threshold":0,"over_act":"disabled","under_threshold": 0,"under_act":"disabled"},{"over_threshold":0,"over_act":"di sabled","under_threshold":0,"under_act":"disabled"}]}],"ext_sensors":{"temperature_unit":"C"},"ext_temperature":{" 0":[{"overtemp_threshold_tC":0.0,"overtemp_threshold_tF":32.0,"u ndertemp_threshold_tC":0.0,"undertemp_threshold_tF":32.0,"ov ertemp_act":"disabled","undertemp_act":"disabled","offset_tC ":0.0,"offset_tF":0.0},{"overtemp_threshold_tC":0.0,"overtem p_threshold_tF":32.0,"undertemp_threshold_tC":0.0,"undertemp _threshold_tF":32.0,"overtemp_act":"disabled","undertemp_act ":"disabled","offset_tC":0.0,"offset_tF":0.0}]},"ext_humidity":{}}'. Code: 'OK' (OK)
    23/02/2021 11:13:36
    AK Shelly
    Error
    [641] 483FDA82BF81.shellyuni: Execute 'settings': Status: 'Error' (). Error: 'Unable to cast object of type 'RestSharp.JsonArray' to type 'System.Collections.Generic.IDictionary`2[System.String,System.Object]'.'. Response: '{"device":{"type":"SHUNI-1","mac":"483FDA82BF81","hostname":"shellyuni-483FDA82BF81","num_outputs":2},"wifi_ap":{"enabled":false,"s sid":"shellyuni-483FDA82BF81","key":""},"wifi_sta":{"enabled":true,"ssid":"I oT","ipv4_method":"dhcp","ip":null,"gw":null,"mask":null,"dn s":null},"wifi_sta1":{"enabled":false,"ssid":null,"ipv4_meth od":"dhcp","ip":null,"gw":null,"mask":null,"dns":null},"mqtt ": {"enable":false,"server":"192.168.33.3:1883","user":"","id": "shellyuni-483FDA82BF81","reconnect_timeout_max":60.000000,"reconnect_t imeout_min":2.000000,"clean_session":true,"keep_alive":60,"m ax_qos":0,"retain":false,"update_period":30},"coiot": {"update_period":15},"sntp":{"server":"time.google.com","ena bled":true},"login":{"enabled":false,"unprotected":false,"us ername":"admin"},"pin_code":"uaiDqQ","name":null,"fw":"20201 124-093042/v1.9.0@57ac4ad8","factory_reset_from_switch":true,"discovera ble":false,"build_info":{"build_id":"20201124-093042/v1.9.0@57ac4ad8","build_timestamp":"2020-11-24T09:30:42Z","build_version":"1.0"},"cloud":{"enabled":true ,"connected":true},"timezone":"Europe/London","lat":51.414101,"lng":-1.318650,"tzautodetect":true,"tz_utc_offset":0,"tz_dst":fals e,"tz_dst_auto":true,"time":"11:13","unixtime":1614078816,"a ctions":{"active":true,"names":["out_on_url","out_off_url","btn_on_url","btn_off_url","longp ush_url","shortpush_url","out_on_url","out_off_url","btn_on_ url","btn_off_url","longpush_url","shortpush_url","adc_over_ url","adc_under_url","ext_temp_over_url","ext_temp_under_url ","ext_temp_over_url","ext_temp_under_url","ext_temp_over_ur l","ext_temp_under_url","ext_temp_over_url","ext_temp_under_ url","ext_temp_over_url","ext_temp_under_url","ext_hum_over_ url","ext_hum_under_url"]},"hwinfo":{"hw_revision":"prod-202008", "batch_id":0},"mode":"relay","longpush_time":800,"relays ":[{"name":null,"appliance_type":"General","ison":false,"has_ti mer":false,"default_state":"off","btn_type":"toggle","btn_re verse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false,"sc hedule_rules":[]},{"name":null,"appliance_type":"General","ison":false,"has_ timer":false,"default_state":"off","btn_type":"toggle","btn_ reverse":0,"auto_on":0.00,"auto_off":0.00,"schedule":false," schedule_rules":[]}],"adcs":[{"range":12,"relay_actions":[{"over_threshold":0,"over_act":"disabled","under_threshold": 0,"under_act":"disabled"},{"over_threshold":0,"over_act":"di sabled","under_threshold":0,"under_act":"disabled"}]}],"ext_sensors":{"temperature_unit":"C"},"ext_temperature":{" 0":[{"overtemp_threshold_tC":0.0,"overtemp_threshold_tF":32.0,"u ndertemp_threshold_tC":0.0,"undertemp_threshold_tF":32.0,"ov ertemp_act":"disabled","undertemp_act":"disabled","offset_tC ":0.0,"offset_tF":0.0},{"overtemp_threshold_tC":0.0,"overtem p_threshold_tF":32.0,"undertemp_threshold_tC":0.0,"undertemp _threshold_tF":32.0,"overtemp_act":"disabled","undertemp_act ":"disabled","offset_tC":0.0,"offset_tF":0.0}]},"ext_humidity":{}}'. Code: 'OK' (OK)
    Lots and lots of them
    One of the devices, shows:
    Error: Unable to cast object of type 'RestSharp.JsonArray' to type 'System.Collections.Generic.IDictionary`2[System.String,System.Object]'.
      MFULLER Sorry, I missed your post somehow, will check.
        In the mean time - the current version is 4.0.0.37 - is it any better?
          Ah, ok https://forums.homeseer.com/forum/hs...ure-probe-data
