Ak Shelly with HSBuddy
    Hi
    AK Shelly works great but i noticed a possible issue with HSBuddy. It seems that "related devices" in HSbuddy don't show their values. All other device with "related devices" show the values. HSBudy has an option in settings to always show values or never show values. For my AK SHelly device this setting does not make a difference. It is possible I'm overlooking something. thanks Joe
    Can you please post some screenshots
      A little more information... I am using a Shelly 1 with the Temperature add on. The first screen shot shows "all" devices and the temperature is visable. The second screen shot shows the "favorites" tab with the device and related devices. The temperature is not visible even though i have the "Show value: Always" checked. You can see in the same photo another temperature sensor which is a "related device" for "Color Control" does show the temperature. Of course, this could be an issue with the HSBuddy app. thanks for your help. Joe
        What plugin is "Color Control" from?
        [EDIT]
        Is it possible that "related device" is shown if there's only one device? Can you disable AKShelly plugin and delete all but one device?
          That comes from the ZWave plugin.
              Not sure what you mean by delete all devices but one. I have many devices set up in Homeseer.
              It looks like this could be a limitation of HSbuddy or Homeseer itself. In HSBuddy, if i remove all but 2 of the related devices from favorites for this devide, in this case i left in the 2 temperatures, they both show their values. If i add a 3rd related device to favorites (such as the switch control), then it goes back to the format where the values for the related device are not shown.
              In the homeseer UI, it also does not show the values of the related devices.
              Looks like i might have to live with it the way it is and drill down to see the temperature. Thanks for your time.
                That's what I meant.
                In recent HS update they introduced child devices priority, I will experiment...
                  Can you please post screenshots of "Advanced Information" from Status/Graphics device settings for parent and child devices for "Color Control"
                    I'm not sure how to find the actual parent. I attached a screen shot of what i see when i go to the status/graphics tab and also the advanced info for Color Control. All of the features say they have a child relationship.
                      Thank you
                        Color Control has API type 4 (LegacyPlugin), which is not really supported in HS4, it's used for devices from HS3 plugins and may behave differently
