Status device Shelly 2.5
    #16
    What do you mean by "The buttons I can not see if it is open or closed"?
      #17
      With the buttons I can open en close the blinds but I can not see on the button if they are open or closed.
        #18
        Ok, I guess two devices it is
          #19
          Ver 4.0.0.58 - Split Shelly25.Roller in two devices
          antoon please try and provide Log - I can't test myself
            #20
            Alex,
            The slider device is working and gives also the right value in %
            But the Roller device is still the same.
            When I press open or close the blind goes open or close and that text is also standing then, but after it has come at the end of position the device text change again to stop.
            Click image for larger version  Name:	image_105377.jpg Views:	12 Size:	38.6 KB ID:	1498184
              #21
              I'll fix it.
              Forgot to tell you, you need to delete the Roller device, so it will be recreated without the slider after plugin restart
                #22
                And I need the log when you control the roller, not when you just start the plugin.
                And please post the log as text, not screenshot.
                  #23
                  It's strange that the RollerPos device is different to other devices - the location is "Shelly", not "AK Shelly", but you can change it manually
                    #24
                    I will check things when I am home later and send you the Log
                    Location I had changed to AK Shelly, thats why the RollerPos was in Shelly
                      #25
                      Hereby the Log when I press open, till it is open.
                      Also I deleted the Roller device and let it new create, see screenshot.
                      Antoon
                      [1187] 98CDAC2D2BB6.Roller: RollerStatus stop 'open' (pos. 100)
                      9-24-2021 13:04:18
                      AK Shelly
                      Info
                      [1188] 98CDAC2D2BB6.RollerPos: RollerStatus stop 'open' (pos. 100)
                      9-24-2021 13:04:13
                      AK Shelly
                      Info
                      9-24-2021 13:04:13
                      AK Shelly
                      Info
                      9-24-2021 13:04:08
                      AK Shelly
                      Info
                      9-24-2021 13:04:08
                      AK Shelly
                      Info
                      9-24-2021 13:04:03
                      AK Shelly
                      Info
                      [1187] 98CDAC2D2BB6.Roller: RollerStatus open 'close' (pos. 0)
                      9-24-2021 13:04:03
                      AK Shelly
                      Info
                      [1188] 98CDAC2D2BB6.RollerPos: RollerStatus open 'close' (pos. 0)
                      9-24-2021 13:03:58
                      AK Shelly
                      Info
                      9-24-2021 13:03:58
                      AK Shelly
                      Info
                      9-24-2021 13:03:53
                      AK Shelly
                      Info
                      9-24-2021 13:03:53
                      AK Shelly
                      Info
                      9-24-2021 13:03:48
                      AK Shelly
                      Info
                      9-24-2021 13:03:48
                      AK Shelly
                      Info
                      9-24-2021 13:03:43
                      AK Shelly
                      Info
                      9-24-2021 13:03:43
                      AK Shelly
                      Info
                      9-24-2021 13:03:38
                      AK Shelly
                      Info
                      9-24-2021 13:03:38
                      AK Shelly
                      Info
                      9-24-2021 13:03:37
                      AK Shelly
                      Info
                      [1187] 98CDAC2D2BB6.Roller: MoveRoller result: 'open', current_pos: 0, stop_reason: normal
                      9-24-2021 13:03:37
                      AK Shelly
                      Info
                      [1187] 98CDAC2D2BB6.Roller: MoveRoller: 'open'
                      9-24-2021 13:03:33
                      AK Shelly
                      Info
                      [1187] 98CDAC2D2BB6.Roller: RollerStatus stop 'close' (pos. 0)
                      9-24-2021 13:03:33
                      AK Shelly
                      Info
                      [1188] 98CDAC2D2BB6.RollerPos: RollerStatus stop 'close' (pos. 0)
                        #26
                        antoon try ver 4.0.0.59 - hopefully it should work.
                        Also I hide/unhide unused Relay / Roller devices (depending on Mode), please verify (you might need to refresh the page)
                          #27
                          Alex,
                          Now it says "Stop Open"or "Stop Close" and the icons for open and close are not using, still used the "Stop"icon
                          See screenshots and Log
                          first one is with blind open
                          second while closing
                          third when blind is closed
                          9-24-2021 16:51:21
                          AK Shelly
                          Info
                          9-24-2021 16:51:21
                          AK Shelly
                          Info
                          9-24-2021 16:50:55
                          AK Shelly
                          Info
                          [1187] 98CDAC2D2BB6.Roller: RollerStatus close 'open' (pos. 100)
                          9-24-2021 16:50:55
                          AK Shelly
                          Info
                          [1188] 98CDAC2D2BB6.RollerPos: RollerStatus close 'open' (pos. 100)
                          9-24-2021 16:50:52
                          AK Shelly
                          Info
                          [1187] 98CDAC2D2BB6.Roller: MoveRoller result: 'close', current_pos: 100, stop_reason: normal
                          9-24-2021 16:50:52
                          AK Shelly
                          Info
                          [1187] 98CDAC2D2BB6.Roller: MoveRoller: 'close'
                          Click image for larger version  Name:	image_105415.jpg Views:	5 Size:	41.2 KB ID:	1498410
                          Click image for larger version  Name:	image_105416.jpg Views:	5 Size:	38.5 KB ID:	1498411
                          Click image for larger version  Name:	image_105417.jpg Views:	5 Size:	38.6 KB ID:	1498412
                            #28
                            It's hard to decide how to display the status, because when roller stops - the status is "stopped" - not "open" or "close".
                            If I only display "open" or "close", but not "stopped" - how do you know when it's moving and when it's stopped?
                            What's your view?
                              #29
                              For me it is not a problem when I not can see if it is moving.
                              Is it not possible to add the open close to the RollerPos device.
                              When I take a look to me Zwave roller device it has also a kind of rollerpos device.
                              This one says open and close with corresponding icon.
                              And the roller device says opening closing or stopped.
                                #30
                                Anything is possible. What's your ideal view?
