Status device Shelly 2.5
    #31
    For me it would be most ideal if I have about the same as my Z-wave device.
    That means 1 device with the buttons Start Opening, Start Closing and stopped, Icon is not that important (like the Roller Device)
    And 1 status device with open and closed and associated Icon.
    I assume that I can make 25%, 50% and 75% in HSTouch myself.
      #32
      Originally posted by alexbk66 View Post
      antoon try ver 4.0.0.59 - hopefully it should work.
      Also I hide/unhide unused Relay / Roller devices (depending on Mode), please verify (you might need to refresh the page)
      Today I added a new Roller device, but the Unused relay device is still there
        #33
        I can add 25%, 50% and 75% buttons, not a problem.
        Can you please post a screenshot of your ideal device.
          #34
          This is how my Z-wave devices are looking.
          This is working fine for me.
          If you need more info let me know.
            #35
            If you want, you can send me the images (for 0, 25, etc.) and I can add them to the devices
              #36
              Do you actually want 25, 50, 75 controls, or just status?
                #37
                Status is just fine.
                Icons send PM
                  #38
                  Ver 4.0.0.61 I added the icons and improved RollerPos device. It's more complicated than Fibaro device because open/close states and commands are different to the position state and commands.
                  Since I can't test - please test thoroughly.
                  But now I can't see the value of having two devices? If we just add the "Stop" button to the RollerPos, then we don't need Roller device?
                    #39
                    Everything works perfectly.
                    Only if I set it to 50%, the roller shutter is almost closed.
                    But I think that's a Shelly problem, because the App also says 50%, even though I calibrated the shutter
                    And indeed if you add the stop button to the RollerPos, we don't need the Roller device.
                    ps I still see the relay outputs
                      #40
                      Can you check status of "Hide From All Views" for the relay devices, they should be hidden
Name:	Screenshot 2021-09-28 022943.png
                        #41
                        Setting seems to be good, nevertheless I see the device.
                          #42
                          My mistake, I overlooked this one
                            #43
                            Me too
                              #44
                              antoon , Ver 4.0.0.62 - Roller: Moved "Stop" button to ChildDeviceRollerPos
                              I removed the first ChildDeviceRoller device, see if it's sufficient to have one device.
                                #45
                                Hi Alex,
                                I will upgraden and test.
                                Let you know.
                                Verstuurd vanaf mijn SM-N975F met Tapatalk
