SNZB-01 Wireless Switch - unable to pair
    Having a lot of trouble figuring out how to pair my Smart Switch. When I try to add device in the config page of your plug-in I get Unknown.Unknown at IP 127.0.0.1
    I am able to directly add the device in the Zigbee plugin, but no configuration or device type string information populates
    Please provide more info, I don't know what you did and what doesn't work.
    What steps did you try exactly?
    What "Smart Switch"?
    Please provide some screenshots.
    Please provide Log (from HS log filter by plugin - FILTER FROM - and EXPORT to file.
    Please provide output from Tools => help.
    The device should be discovered by mDNS (Zeroconf) automatically. It didn't work?
    If you have to add the device manually - you need to enter the IP address. I noticed in the main thread the config screens are still from HS3 - I need to update the instructions.
      Actually, SNZB-01​ is Zigbee switch, but the plugin only supports "Sonoff DIY line" - please read the original post.
        Sonoff Wireless Switch SNZB-01 Zigbee compatibility (blakadder.com)
          At the risk of hijacking this thread - tell me if I should move this post elsewhere - I see that these SNZB-01 switches can be used as on / off switches in the TUYA app. The first press switches the controlled device / event on whilst a second press of the same type (short, long, double) switches the device / event off.
          Can this be replicated in JowieHue?
            If it's supported by TUYA - you probably want the Tuya plugin https://forums.homeseer.com/forum/hs.../tuya-homeseer.
            But I think since it's a Zigbee device, so you may try https://forums.homeseer.com/forum/hs...ee-homeseer-aa
              Thanks Alexbk66 - will redirect my enquiry - I obviously got my forums (forae?) confused.
