Hi,
I have just been given an automation module for my Aircon system that uses an RS232 interface and I found this Homeseer plugin which I'm hoping is exactly what I need, but just want to check if it can do the following for me?h
1) Create a device showing the current status of the System (On/Off, Fan Speed, Mode etc) and the ability to then change these so I can turn the system on/off or from heat to cool via Homeseer.
2) Create a device (or maybe sub-device) for each Zone (Room) showing the status of each zone and the ability to change these (open/close zone or set temperature)
I have attached the documentation for the module, note in Section 4.8 it can send automatic status updates to keep my Homeseer devices up-to-date.
Any guidance or hints on how to set this up would be greatly appreciated as I've not used this plugin or RegEx expressions before.
Many thanks
Richard
Many thanks
Richard
