Originally posted by risquare
View Post
From their docs:
keypress/<KEY> | Equivalent to pressing down and releasing the remote control key identified after the slash. You can also use this command, and the keydown and keyup commands, to send keyboard alphanumeric characters when a keyboard screen is active, as described in Keypress Key Values. This command is sent using an HTTP POST with no body. |
I greatly your help so far with this. Of all the community forums I participate in, the best folks, by far, are here.
Update: I have the code to pull the URL and port from an .ini file. Just need to figure out how to construct the URL inside the keypress code without it needing to be def as a constant.
