I found out there is a well documented API for my Viessmann furnace, and wish to communicate using Big5 (or 6?).
It is located here: https://developer.viessmann.com/en/doc/getting-started
I started to read the documentation and found here : https://developer.viessmann.com/en/doc/authentication that :
"The response to the authorization request is returned in HTML and contains a login form. Therefore, the authorization request must be called with a browser and should not be executed via a program or script."
Will this be true for Homeseer/Big5, or can I start setting this up ?
Pierre
