About Big6
This topic is closed.
This is a sticky topic.
    About Big6
    Big6's slogan is "Adopt any device" and for a good reason. Big6 could be the last plug-in you'll ever need. The best is that you don't need any programming skills to enjoy the many powerful features that it offers to connect and manage practically any networked device.
    - no programming knowledge or skills needed
    Big6 is communication plug-in for non programmers to connect variety of devices to HS4. It supports 6 major protocols - HTTP, TCP, RS232 (a.k.a. Serial), MQTT, UDP and Chat. It also supports popular data formats and protocols such as JSON, oAuth2, REST, curl, RegEx and more.
    Protocols supported
    HTTP - GET, POST, PUT
    TCP - including Telnet and SSH
    RS232, RS485 a.k.a Serial Interface a.k.a COM ports
    MQTT - including wild cards in topics
    UDP
    Chat - Telegram and Slack
    We like to think about Big6 as the last and only plug-in you need as it can adopt practically any device and link it to HS4 for both control and status reports.
    Big6 comes with
    7 HS4 Event triggers
    7 HS4 Event actions
    Well documented online click here
    Big6 creates/updates HS4 devices automatically from the income data over any of the supported interfaces/protocols.
    Security ! Supports following HTTP authentication methods plus all build-in security in the above protocols.
    oAuth2
    Basic
    Bearer Token
    Digest
    JWT
    Big6 has powerful pre- and post-processing of the outgoing and incoming data using expressions. Expressions are easy to understand for non programmers to use, well documented with examples.
    NEW ! Chat-GPT knows Big6 and can help you with creating expressions for parsing complex incoming data.
    Online documentation for Big6 is available here.
