I setup the Telegram as the instructions, not very familiar with it so bear with me. I was able to via the telegram bot to send a text, it works as expected. When I try to send a message to the bot using the following syntax in the event, write the message "tes" to the profile TelegramProfile I do nort get "Tes" in the bot. What am I doing wrong?
Telegram Outgoing messages issues
Thank you for the super fast reply. I tried different combinations without success. I enabled the log but it does not show anything in there. By the way, I'm using the beta version, would it make a difference? Any other test that I can do?
Edit: I was able to get the log working, I did not realize that it was on a different tab. I got this message
[CHAT] [ChatConnection] [#PFL:TelegramProfile] failed to send message to chat. TelegramProfile (Telegram) - @xxxxChannel - One or more errors occurred. Bad Request: chat not found ( I replace the real channel with xxxChannel)
