Exception has been thrown by the target of an invocation error
    On version 4.2.0.0 of homeseer, I am getting this error on a fresh install. Events that were already setup work fine, but when trying to setup a brand new event, I get this error when selecting the plugin (and unable to select the usual options that follow). Any ideas what would cause this, or how to completely remove the plugin and reinstall to maybe clear it? Thanks!
    Found out the issue (wish the error was more informative, but most likely that's a Homeseer issue not the plugin. Anyways, I had two switches in the same room with the same root device name. Changed the name, plugin works fine now!
      Good to know. I'll check and see if there's anything I can do about it.
