I installed the Samsung Zigbee Button in Hubitat and brought it into HomeSeer with this plug in. In Hubitat the button has double tap, hold, and push. Only 2 of these come through, with the missing one being double tap. Just wondering if anyone has installed this device and brought all 3 into HomeSeer. By the way, battery and temperature devices are brought into HomeSeer. Thanks.
Samsung Zigbee Button may be missing one device
What is needed to evaluate is the disclosure provided by Maker API for this device. If debug is enabled in the plugin then this data is collected in file hubitat_debug.txt which is in the \Data\hubitat or \Data\mcsHubitat folder, depending upon HS3 vs. HS4 plugin. It is produced on plugin startup or with use of the Sync button in the plugin. It can be posted or emailed to mcsSolutions at CenturyTel dot net.
